Multiple rings not showing up as column in Fusion Report
2857
04-23-2014 07:45 AM
TomMacDonald
I'm trying to replicate the columns representing different rings such as in the "Market Profile" report.  My Fusion Designer looks like this:
http://i.imgur.com/nys7FsQ.png
However when running report on a 3 ring driving distance buffer I get the seperate "tables" for each ring like this:
http://i.imgur.com/u4NqxdS.png
How do I get it so each ring has its own column?
Jason_RobinsonRobinson
Tom,
In fusion report designer if you are looking to create a three ring column-type report is to select the Market Profile in Step 1 and then drag over the from Step 2 to Step 3 the the first row with [AreaDesc].  Check out the screen shot below.
[ATTACH=CONFIG]33352[/ATTACH]
Regards,
Jason R.
TomMacDonald
I'm not getting "Market Profile" on my setup.  Here's a screenshot:
http://i.imgur.com/uLzGd7W.png
Tom,
I see you are working with 2011/2016 vintage in Business Analyst.  Are you on software version 10.1 or 10.2 or newer?
Regards,
Jason R.
TomMacDonald
BA build is #10.1.0.85. ArcGIS is 10.1 SP1 Build 3143 Basic License.
Tom,
Took the memory banks a bit to kick in.  Actually the Market Profile was not available in Business Analyst for the 2011/2016 data set as this was the first release that was census 2010 based and an updated ACS release (which replaced the SF3/census long from from the census 2000) was not available yet which impacted Market Profile report.  If you take a look at the 2011 BA Desktop Variable and Report List.xlsx at C:\ArcGIS\Business Analyst\US\Documentation this will confirm what reports are available.
That said there is another three ring based template would be the Store Report in Blank Templates in the Fusion Report Designer.  Drag over the [AreaDesc]/Page Break section over to the step 3 (report preview).
Regards,
Jason R.
