Create custom calculator widget in arcgis experience builder WebApp
3306
05-29-2023 08:11 PM
Ankitkhanna
I have a use case where on WebApp built using ArcGIS Experience Builder requires a widget where user can input some values and the calculation occurs and output gets displayed based on logic.
The logic is just like simple calculator, where user has to enter 2 numeric values and select operator to get the output.
Is it something achievable in Experience Builder or any other ArcGIS online app?
HollyTorpey_LSA
I don't know the answer, but I have the same question. I need to build an app in which a user would click a location on a map (or select a polygon), provide a value, and then see a result calculated from a formula that uses the input location and user-input value. A smart form in the Edit widget with an input field and a couple of read-only calculated fields (one to pull the necessary value from the map location and one to calculate the result) would work great if only I could hide the "Save" button. I don't need the user-entered variable or the calculated result to persist; I only want them temporarily displayed for the user.
- Holly
JWMPoel
Hi, for my thesis I am looking for a similar function / custom widget. Did you manage to find one or make one yourself? If not, how did you accomplish this task?
- Jasper
HollyTorpey_LSA
Personally, I have not come up with a solution yet, but I did submit an Experience Builder idea for what I think would work. I got some helpful feedback from @AlixVezina about an existing widget that I could modify to develop my own custom widget that could do what I need. Unfortunately I rarely have time or budget to do custom development at my job.
Here's the link to the idea I posted: https://community.esri.com/t5/arcgis-experience-builder-ideas/smart-form-widget-for-on-the-fly-calcu.... Feel free to upvote it or add your own use case to help the idea gain traction if you think it sounds useful. 🙂
- Holly
