Can anyone give advice on why the nearest_feature_attributes tool as a part of the attribute assistant will not work?
1228
08-29-2021 03:40 PM
LaurenLeverett
Hi All! I have been trying out the Attribute Assistant to auto populate some fields as I edit, and for some reason when I try the Nearest_Feature tool it works, but I cannot get the Nearest_Feature_Attributes tool to work. I have been following the guide online but for some reason it won't populate. Could anyone look at my inputs (in the attached photo) and see if anything is incorrect?
The goal was to copy values from the LS_data_Aug2021_trim table including LS_Nam_OM, and LS_LOC_OM to similar fields in the Pumps_AA_trial table. You can see the other nearest feature tool below it that does work. I am wondering if it has something to do with the field name, but the instructions were to leave it blank or null.
MikeMillerGIS
Esri Frequent Contributor
I think you need to add the neighborhood value:
Neighborhood (Optional) <Null> (Default) Only intersecting features are considered. Number Maximum distance to search for nearest feature.
