Add Field to hosted AGOL feature layer (Elections)
3873
11
10-11-2019 09:01 AM
JayJohnsonWashoeCounty
With the help of ESRI's Matthew Twietmeyer I've deployed the election Management Solution and need to add a field to the ElectionGeography hosted feature layer (Election Day Metrics table).   I am the owner.
I open the item details, go to Data, and select the Election Day Metrics table.
In both Table and Fields views I see no "Add" functionality as described here:
Add or delete a field—ArcGIS Online Help | Documentation
Strangely, I am able to add a field to the ElectionResults hosted layer (ElectionResults table).
Any tips on how to accomplish this or why I don't see what I'm expecting here?
Jay
Jay
Washoe County GIS
To finish this thread out for the benefit of others who may run into this issue, the problem was that I was being foiled by our corporate security.
After working extensively with ESRI tech support and white-listing various domains, we reached a point where the required access exceptions to AWS were just too broad of an ask for our security team.
Ultimately I was successful by re-deploying the Solution from outside of our organization's firewall (via our public WiFi connection).
Jay
Jay
Washoe County GIS
ChelseaRozek
MVP Regular Contributor
I'm running into the same problem it seems. Why is the Election solution different? I can add Fields to other hosted layers. Did you ever find out what about Deployment makes it different?
