Add existing signals to existing cabinets in Signal Management Solution
254
11-20-2025 06:25 AM
VeronicaS
@DanielWickens I am working on deploying the Signal Management Solution. I am starting with existing pole data but will have to manually add the signals and cabinets. I set up a couple intersections with test data to explore how the solution works in various situations. One issue that I ran into is where I have an existing signal and existing cabinet and want to add the signal as a related record to the existing cabinet. I have tried adding the signal to the cabinet in the editor map and the experience but the only option I see is to add a new signal feature, not a signal feature that already exists in the map. The only other option I have found is to copy the GlobalID from the signal to the cabinet through the attribute table. I don't think copying the GlobalID would be a viable option field data collection. Is there a way to add an existing signal feature to an existing cabinet without creating a new signal feature? What am I missing?
DanielWickens
@VeronicaS - The best way to relate existing signals and cabinets is using the Pro Project to edit feature relationships. Download, unzip, and open the Signal Data Management Pro Project, and connect the data sources to the signal, cabinet, and pole layers of the solution in your portal. Then select the cabinet and signal you want to relate. With both features selected, open the Attributes pane, expand the Cabinet feature, right-click Signals, and select Add Selected to Relationship. I've attached some screenshots below to help demonstrate the process. Reach out if you need anything else.
VeronicaS
Thank you so much for for getting back to me. I appreciate the response. I was hopeful there would be a way to relate the features in AGOL or field maps, it will change our data collection workflow but I am prepared to proceed with the steps you outlined above.
