Infographics for Fire Accreditation Analysis
2471
11-30-2022 06:35 AM
The Fire Accreditation Analysis Solution contains an ArcGIS Pro project that creates several supporting documents for the accreditation process.  One of these documents can be an Infographic as part of task step 2A.7 in the ArcGIS Pro project.  When upgrading to Pro 3.0.2, a slight change occurred on how these infographics are shared.  To access the Fire District Infographic referenced, complete the following steps:
We would also welcome any further feedback on infographics that could be useful to you in the accreditation process.  For instance, are there more variables supporting EMS calls that deserve a separate infographic?  we could potentially share more infographics with the community in this same way.
Comments
Baylie_Scott
Esri Alum
As of June 2024, if you have deployed Accreditation Analysis and are unable to see the infographic, complete the following steps in ArcGIS Pro:
  1. In ArcGIS Pro, make sure you are in the map tab in the ribbon.
  2. Click the down arrow under Infographics in the Inquiry group.
  3. Click Configure Infographics.
  4. Select Use specific country.
  5. Click the file folder and select Esri 2023.
  6. Click OK.
  7. Open the 2.A.7 task and follow the instructions as normal.
CherylScott4
@Baylie_Scott I have joined the group, but when I follow the steps in the comment, the drop arrow under Infographics in the Inquiry group is greyed out. Is there another way to complete this?
Baylie_Scott
Esri Alum
Hi, @CherylScott4! What version of ArcGIS Pro are you using and what user type and role do you have? We are testing this to see if we can figure out what is happening.
Baylie
CherylScott4
Hi, @Baylie_Scott ! I am using Pro version 3.3.2. And for ArcGIS Online, I have a user type of Creator and a Role of Administrator.
Thanks!
Version history
Last update:
‎11-30-2022 06:40 AM
Updated by:
Contributors
