where to put the "Code Behind C#" code?
515
08-14-2012 06:08 AM
MichaelStiso
Hi. I'm using Microsoft Expression Blend to work with the ArcGIS SDK for WPF, and I'm a bit new to both. I have been trying to integrate some of the interactive samples in the "ArcGIS API for Silverlight" section into my code, and I am a bit confused about where to put the code in the "Code Behind C#" tab of those samples.
More specifically, I know how to find the code-behind files for MainWindow and App (and my various user controls), but I'm not sure in which of those I should put the code-behind from the sample.
For example, this is the code-behind for the ElementLayer sample (http://help.arcgis.com/en/webapi/silverlight/samples/start.htm#ElementLayer):
[INDENT]using System.Windows;
using System.Windows.Controls;
namespace ArcGISSilverlightSDK
[INDENT] public partial class ElementLayer : UserControl
[INDENT]  public ElementLayer()
   [INDENT]InitializeComponent();[/INDENT]
  private void RedlandsButton_Click(object sender, RoutedEventArgs e)
   [INDENT]MessageBox.Show("You found Redlands");[/INDENT]
[/INDENT] }
[/INDENT]}
[/INDENT]
I've found through trial and error that I don't put all of that in MainWindow.xaml.cs. Rather, it seems that I need to include just the RedlandsButton_Click method to get things to work. But does that mean I can ignore the rest of the C# code, or do I need to put it elsewhere?
Any tips, or a point toward some relevant documentation, would be appreciated. Thanks much.
AnttiKajanus1
Hi there!
MainWindow.xaml.cs is most likely correct palace but some things to note:
In your case, you can just copy needed code to code-behind after the MainWindow's Constructor
After that you codebehind shoud look more or less like this (just writing out from my head)
public partial class MainWindow : Window
   public MainWindow()
In Wpf, you are using Window control instead of the UserControl so in the code behind
Here ElementLayer defines the name of the class that should be in your case MainWindow. If you are using Window as your control base, then UserControl should be Window.
I would say that follow more ArcGIS Runtime for WPF 1.0 samples that you can find from your computer after you have installed Runtime development tools:
Start -> All Programs -> ArcGIS ->
Runtime SDK 1.0 for WPF ->ArcGIS Runtime WPF Samples 1.0
MichaelStiso
Great, that clears up a bit. Thanks much for the help.
