Smoothing Lines in a List of Points
1308
12-02-2011 06:22 AM
GregEdwards
We are receiving a list of points, and adding them to a map layer as a polyline. Using ESRI tools, how might we convert the line segment into a smoothed line segment using Bezier Spline or an equivalent?
Thank you.
-Greg Edwards
The code looks something like this:
var pointCollection = new Geometry.PointCollection();
//IN LOOP:
pointCollection.Add(Transform.GeographicToWebMercator(new MapPoint(latitude, longitude)));
//AFTER LOOP IS COMPLETED:
var polyline = new Polyline();
polyline.Paths.Add(pointCollection);
polylineList.Add(polyline);
WeifengHe
You can cast the polyline into IPolycurve, then call Smooth method to convert into a smooth curve that containing only Beizer curve segments.
GregEdwards
Which ArcGIS DLL and Namespace is the IPolycurve interface located? Thank you.
BKuiper
