Local Service can't start on windows 8.1
3053
02-26-2014 10:37 PM
YaZhang
I Use Arcgis Runtime Sdk for WPF build my application, On windows 7,there is  no problem.But on windows 8.1, the local services such as LocalMapService can't start, and the ArcGISLocalDynamicMapServiceLayer  is not render the layer. Run the sample application-WPFSampleApplication10.2  also.  Is anyone have the same problem?
MichaelBranscomb
Esri Frequent Contributor
We are not aware of any issues on Windows 8.1 (the whole dev team pretty much run Windows 8.1 now).
Do see any local service/server exceptions?
Is there anything in the localserver log? (you may need to enable logging in the LocalServer Utility)
Do see the MPK(s) unpacked in the expected location?
Cheers
Mike
YaZhang
aha, I got it! If the location which path to RuntimeLocalServer.exe  has any Chinese character�?the RuntimeLocalServer.exe  could not start correctly.
please resove it. Thanks!
the same problem:
http://forums.arcgis.com/threads/101368-Where-is-the-data-LocalFeatureService-saved?p=361122&viewful...
