How to open shape file in ArcGIS Runtime WPF SDK as Graphics/Feature layer
12359
24
01-23-2013 06:23 AM
KevinChan
I googled and followed this tutorial http://www.arcgis.com/home/item.html?id=953a530ada30477d95cc69e788268bc9 and figured out how to import Shape files and Rasters into Runtime.
However, it seems most of the functionality uses a FeatureLayer/GraphicLayer instead an ArcGISLocalDynamicMapServiceLayer that the sample uses.
My question is if there is a way I can import the shape file as a graphics layer or if i can somehow cast my ArcGISLocalDynamicMapServiceLayer as a Graphics layer because shape file is essentially the same as a shape file.
An example is i'm trying to use the FeatureDataGrid() to show the attribute table of my shapep file, but I can't since it requires a graphics layer, not an ArcGISLocalDynamicMapServiceLayer.
Thanks and Regards, Kev
GeorgeFaraj
Hey Dominique,
So this worked for the Rectangle selection tool of the Editor control, but doesn't work with the Line selection tool. Any ideas how to make this work? No features get selected by the line tool.
George
DominiqueBroux
Esri Frequent Contributor
How do you set the line selection tool?
What happens exactly?
Also is it working with others selection modes such as circle:  editor.SelectionMode = DrawMode.Circle; ?
GeorgeFaraj
Hi Dominique, sorry for taking so long to respond, but was tied up in something else.
I have a toolbar, and on one of its buttons click event handler:
if (MapEditor.Select.CanExecute("Keyboard"))
 MapEditor.SelectionMode = DrawMode.LineSegment;
 //MapEditor.Select.Execute("Keyboard");
When I click the toolbar icon, I can click and drag to draw a line, release the mouse click and nothing happens.
Only Rectangle and Point selection modes work, then others do nothing after I release the mouse click.
SaranPon
Thanks Mike, that resolved the problem with the layer not being visible. I can label its features, but I can't select anything with the Editor toolkit control. Why could that be?
I should note that I also add the dynamic service layer onto the map in addition to the feature layer, because the layer has too many features, so I show both with the feature layer set to OnDemand mode.
Hi George,
how did you Label the features of a feature layer? Using a Graphics Layer?
How did you pass the features for that? did you QueryTask?
Currently we are having trouble with this. Could you please let us know your approach which might help us solve our issue?
thanks,
Saravanan
SaranPon
I have loaded a shape file / File GDB file successfully using the method specified here. Is it possible to apply symbology - using ClassificationMethod or some other way?
Please help.
Saravanan
