How to calculate the coordinates of the distance from the beginning of the road
3139
7
11-06-2014 11:12 PM
AnatoliiTerentiev
Dear Gurus!
How to calculate the coordinates of the distance from the beginning of the road on a layer of the line features?
PinhasLiran
You should make the nodes of the line of that've road , each node have coordinate. You can use a tool ET GeoWizards, ET GeoTools and ET Surface for ArcGIS - Downloads
IT works with argis software and it free. In the geowizard you should convert line to points and then you will get the nodes with coordinates.
AnatoliiTerentiev
Sorry, how to this with WPF API?
DanPatterson_Retired
Anatoli, it might be easier if you post your questions in this place assuming that this is the correct one
AnatoliiTerentiev
What I must to do to post question on the another thread ?
Anatolii, , I moved it...keep that link I sent you as one you "follow" then you can select it and post there directly
DominiqueBroux
Esri Frequent Contributor
You can look at this Silverlight Sample that demonstrates how to calculate at client side the shortest distance between a point a set of lines or polygons.
Another option is to calculate at server side using the Geoprocessing tools.
AnatoliiTerentiev
The shortest distance is not the case. Geoprocessing tools  I will see.  I'm looking at the moment the decision in WPF, not in Silverlight. And while I do not understand what means "to do on the server", and how  it is associated with the MAP service. I will try to do this using arcobjects.    Thank you.
P.S. Sorry. I understood everything. In my case server and client side are on one computer.
