GroupLayer: Layer pointer should be locked before being accessed.
I'm experiencing problems when trying to remove a GroupLayer from the Map. It keeps crashing on the NativeLayerPointer with the following error
"Layer pointer should be locked before being accessed." when trying to retrieve the pointer.
Is there a specific way how GroupLayers should be removed ?
How can i provide more debug information to Esri so this can be fixed or resolved? I'm not sure if I can provide a PoC.
Thank you
EDIT 2:
I think it is a threading issue when multiple layers are being added to the GroupLayer, which causes the _lockedOnThreadId, _lockCount to be out of sync, but this is a guess. I'm further investigating.
There should probably be a lock on the '_lockCount' integer.
EDIT 1: Call stack:
System.InvalidOperationException: Layer pointer should be locked before being accessed.
at ESRI.ArcGIS.Client.Runtime.NativeLayerPointer.get_Ptr()
at ESRI.ArcGIS.Client.Runtime.NativeLayerPointer.op_Implicit(NativeLayerPointer p)
at ESRI.ArcGIS.Client.Runtime.NativeGroupLayer.RemoveLayer(Layer layer)
at ESRI.ArcGIS.Client.Runtime.NativeGroupLayer.ClearChildLayers(IEnumerable`1 layers)
at ESRI.ArcGIS.Client.Runtime.NativeGroupLayer.Dispose(Boolean disposing)
at ESRI.ArcGIS.Client.Runtime.NativeLayer.Dispose()
at ESRI.ArcGIS.Client.Runtime.NativeGroupLayer.Dispose()
at ESRI.ArcGIS.Client.NativeMap.RemoveLayer(Layer layer)
at ESRI.ArcGIS.Client.DrawingSurface.RemoveLayer(Layer layer)
at ESRI.ArcGIS.Client.Map.RemoveMapLayer(Layer layer)
at ESRI.ArcGIS.Client.Map.Layers_CollectionChanged(Object sender, NotifyCollectionChangedEventArgs e)
at System.Collections.Specialized.NotifyCollectionChangedEventHandler.Invoke(Object sender, NotifyCollectionChangedEventArgs e)
at System.Collections.ObjectModel.ObservableCollection`1.OnCollectionChanged(NotifyCollectionChangedEventArgs e)
at System.Collections.ObjectModel.Collection`1.Remove(T item)
at xyz.LayerManagement.LayerManager.RemoveLayer(Layer layer) in xyz\LayerManager.cs:line 463
at XXXViewModel.ExecuteRemoveLayerCmd(Object parameter) in XXXViewModel.cs:line 391
at DelegateCommand.Execute(Object parameter) in DelegateCommand.cs:line 117
at Telerik.Windows.Controls.RadMenuItem.ExecuteCommand() in c:\TB\117\WPF_Scrum\Release_WPF\Sources\Development\Controls\Navigation\Menu\RadMenuItem.cs:line 3202
at Telerik.Windows.Controls.RadMenuItem.OnClickImpl() in c:\TB\117\WPF_Scrum\Release_WPF\Sources\Development\Controls\Navigation\Menu\RadMenuItem.cs:line 1686
at Telerik.Windows.Controls.RadMenuItem.OnClick() in c:\TB\117\WPF_Scrum\Release_WPF\Sources\Development\Controls\Navigation\Menu\RadMenuItem.cs:line 2330
at Telerik.Windows.Controls.RadMenuItem.ClickItem() in c:\TB\117\WPF_Scrum\Release_WPF\Sources\Development\Controls\Navigation\Menu\RadMenuItem.cs:line 3722
at Telerik.Windows.Controls.RadMenuItem.HandleMouseUp() in c:\TB\117\WPF_Scrum\Release_WPF\Sources\Development\Controls\Navigation\Menu\RadMenuItem.cs:line 1667
at Telerik.Windows.Controls.RadMenuItem.OnMouseLeftButtonUp(MouseButtonEventArgs e) in c:\TB\117\WPF_Scrum\Release_WPF\Sources\Development\Controls\Navigation\Menu\RadMenuItem.cs:line 1999
at System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target)
at System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised)
at System.Windows.UIElement.ReRaiseEventAs(DependencyObject sender, RoutedEventArgs args, RoutedEvent newEvent)
at System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args)
at System.Windows.UIElement.RaiseTrustedEvent(RoutedEventArgs args)
at System.Windows.Input.InputManager.ProcessStagingArea()
at System.Windows.Input.InputProviderSite.ReportInput(InputReport inputReport)
at System.Windows.Interop.HwndMouseInputProvider.ReportInput(IntPtr hwnd, InputMode mode, Int32 timestamp, RawMouseActions actions, Int32 x, Int32 y, Int32 wheel)
at System.Windows.Interop.HwndMouseInputProvider.FilterMessage(IntPtr hwnd, WindowMessage msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at System.Windows.Interop.HwndSource.InputFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
at MS.Internal.Threading.ExceptionFilterHelper.TryCatchWhen(Object source, Delegate method, Object args, Int32 numArgs, Delegate catchHandler)
