Calculate distance between MapPoints Arcgis 10.2.2
2350
04-25-2014 12:49 AM
EugenReiswich
Hi, I need to calculate the distance between two MapPoints in say km with ArcGis 10.2.2 for WPF. The examples I've found on google suggest to use a LocalGeometryService. However, I couldn't find this service in Argcis 10.2.2 WPF Beta. Has this service been replaced?
Regards,
Eugen
AnttiKajanus1
Can you specify what SDK you are using? If you are talking about new ArcGIS Runtime for .NET SDK that is in BETA at the moment, we have replaced GeometryService with GeometryEngine.
AnttiKajanus1
EugenReiswich
Thanks, that was the answer I was looking for. Found already the appropriate example in the Arcgis 10.2.2 WPF example application.
