how to disable the default launch image
1700
02-22-2017 12:28 AM
albavoli
how to disable the default launch image so we can create our own splash screen from the code?
LucasDanzinger
Esri Frequent Contributor
Is there a specific platform you are wondering about? Each platform has its own nuances.
albavoli
I have an app on qml and using appstudio u can put the launch image in the resources settings.but i want to remove that because i want to use more than one image so i have created a page to generate a splash screen.Now its possible to disable that functionality from appstudio??
LucasDanzinger
Alba-
I suggest you post this in the AppStudio space. They will be able to better chime in on how this works. If you're using standalone Qt and the Runtime SDK, then the workflow will be different than if you are using AppStudio.
Luke
