Exception in .Net runtime 100.4
2629
5
05-02-2019 06:27 AM
Jean-ChristopheBertolini
Message d'erreur: Internal error exception. Error mapping readback texture memory for reading!: c:\daily_r\rtc\runtimecore\c_api\src\mapping\map_view\geo_view.cpp(205) : error : Exception caught in RT_GeoView_pulse
Several times by day :
Application WPF,
DxDiag :
System Information
      Time of this report: 5/2/2019, 17:13:28
             Machine name: SRV-RDS4
               Machine Id: Unknown
         Operating System: Windows Server 2016 Standard 64-bit (10.0, Build 14393) (14393.rs1_release.190305-1856)
                 Language: French (Regional Setting: French)
      System Manufacturer: Red Hat
             System Model: KVM
                     BIOS: Intel IGD BDSM enabled at 0x00000000, size 2361069436503MB, dev 00:02.0
                Processor: Intel(R) Xeon(R) CPU           X5570  @ 2.93GHz (4 CPUs), ~2.9GHz
                   Memory: 49152MB RAM
      Available OS Memory: 49152MB RAM
                Page File: 3530MB used, 52789MB available
              Windows Dir: C:\Windows
          DirectX Version: DirectX 12
      DX Setup Parameters: Not found
         User DPI Setting: Using System DPI
       System DPI Setting: 96 DPI (100 percent)
          DWM DPI Scaling: Disabled
                 Miracast: Not Available
Microsoft Graphics Hybrid: Not Supported
           DxDiag Version: 10.00.14393.2457 64bit Unicode
DxDiag Notes
      Display Tab 1: The file Unknown is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL).  You may be able to get a WHQL logo'd driver from the hardware manufacturer.
        Sound Tab 1: No problems found.
          Input Tab: No problems found.
DirectX Debug Levels
Direct3D:    0/4 (retail)
DirectDraw:  0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay:  0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow:  0/6 (retail)
Display Devices
          Card name: Unknown
       Manufacturer: Unknown
          Chip type: Unknown
           DAC type: Unknown
        Device Type: n/a
         Device Key: Unknown
      Device Status: Unknown
Device Problem Code: Unknown
Driver Problem Code: Unknown
     Display Memory: Unknown
   Dedicated Memory: n/a
      Shared Memory: n/a
       Current Mode: 1920 x 1200 (32 bit) (32Hz)
        Driver Name: Unknown
Driver File Version: Unknown (Unknown)
     Driver Version: Unknown
        DDI Version: 9Ex
     Feature Levels: Unknown
       Driver Model: Unknown
Graphics Preemption: Unknown
 Compute Preemption: Unknown
           Miracast: Unknown
Hybrid Graphics GPU: Unknown
     Power P-states: Unknown
  Driver Attributes: Final Retail
   Driver Date/Size: 01/01/1601 02:00:00, 0 bytes
        WHQL Logo'd: No
    WHQL Date Stamp: None
  Device Identifier: {D7B71AF4-43CC-11CF-8069-3918AFC2C735}
          Vendor ID: Unknown
          Device ID: Unknown
          SubSys ID: Unknown
        Revision ID: Unknown
 Driver Strong Name: Unknown
     Rank Of Driver: Unknown
        Video Accel: Unknown
        DXVA2 Modes: Unknown
      Deinterlace Caps: n/a
       D3D9 Overlay: Not Supported
            DXVA-HD: Not Supported
       DDraw Status: Not Available
         D3D Status: Enabled
         AGP Status: Not Available
           MPO Caps: Unknown
        MPO Stretch: Unknown
    MPO Media Hints: Unknown
        MPO Formats: Unknown
Sound Devices
            Description: Sortie audio de l’ordinateur distant
 Default Sound Playback: Yes
 Default Voice Playback: Yes
            Hardware ID:
        Manufacturer ID: 1
             Product ID: 100
                   Type: WDM
            Driver Name: {3.0.0.00000005}.{6C26BA7D-F0B2-4225-B422-8168C5261E45}
         Driver Version:  ()
            WHQL Logo'd: No
          Date and Size: , 0 bytes
            Other Files:
        Driver Provider:
         HW Accel Level: Basic
              Cap Flags: 0xF1F
    Min/Max Sample Rate: 100, 200000
Static/Strm HW Mix Bufs: 1, 0
 Static/Strm HW 3D Bufs: 0, 0
              HW Memory: 0
       Voice Management: No
 EAX(tm) 2.0 Listen/Src: No, No
   I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Sound Capture Devices
Video Capture Devices
Number of Devices: 0
DirectInput Devices
      Device Name: Souris
         Attached: 1
    Controller ID: n/a
Vendor/Product ID: n/a
        FF Driver: n/a
      Device Name: Clavier
         Attached: 1
    Controller ID: n/a
        FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
+ Concentrateur USB racine
| Vendor/Product ID: 0x8086, 0x293A
| Matching Device ID: USB\ROOT_HUB20
| Service: usbhub
| Driver: usbhub.sys, 10/9/2017 04:37:27, 500576 bytes
| Driver: usbd.sys, 7/16/2016 15:17:59, 32608 bytes
+-+ Périphérique d’entrée USB
| | Vendor/Product ID: 0x0627, 0x0001
| | Matching Device ID: USB\Class_03
| | Service: HidUsb
| | Driver: hidusb.sys, 8/6/2016 05:47:49, 38400 bytes
| | Driver: hidclass.sys, 3/6/2019 08:08:54, 156672 bytes
| | Driver: hidparse.sys, 3/6/2019 08:10:34, 40960 bytes
| +-+ Souris HID
| | | Matching Device ID: HID_DEVICE_SYSTEM_MOUSE
| | | Service: mouhid
| | | Driver: mouhid.sys, 7/16/2016 15:17:59, 32256 bytes
| | | Driver: mouclass.sys, 7/16/2016 15:17:59, 59232 bytes
Gameport Devices
PS/2 Devices
+ Clavier standard PS/2
| Matching Device ID: *PNP0303
| Service: i8042prt
| Driver: i8042prt.sys, 7/16/2016 15:17:59, 114176 bytes
| Driver: kbdclass.sys, 7/16/2016 15:17:59, 62304 bytes
+ Périphérique clavier du Bureau à distance
| Matching Device ID: TS_INPT\TS_KBD
| Service: terminpt
| Driver: terminpt.sys, 7/16/2016 15:18:07, 38752 bytes
+ Périphérique souris du Bureau à distance
| Matching Device ID: TS_INPT\TS_MOU
| Service: terminpt
+ Souris compatible PS/2
| Matching Device ID: *PNP0F13
| Service: i8042prt
Disk & DVD/CD-ROM Drives
      Drive: C:
 Free Space: 32.8 GB
Total Space: 101.9 GB
File System: NTFS
      Model: QEMU QEMU HARDDISK SCSI Disk Device
System Devices
     Name: Contrôleur IDE PCI Bus Master Intel(R) 82371SB
Device ID: PCI\VEN_8086&DEV_7010&SUBSYS_11001AF4&REV_00\3&13C0B0C5&3&09
   Driver: C:\Windows\system32\DRIVERS\intelide.sys, 10.00.14393.0000 (English), 7/16/2016 15:18:03, 19296 bytes
   Driver: C:\Windows\system32\DRIVERS\pciidex.sys, 10.00.14393.0000 (French), 7/16/2016 15:18:03, 52576 bytes
   Driver: C:\Windows\system32\DRIVERS\atapi.sys, 10.00.14393.0000 (English), 7/16/2016 15:18:03, 28512 bytes
   Driver: C:\Windows\system32\DRIVERS\ataport.sys, 10.00.14393.2273 (French), 4/28/2018 08:45:36, 191832 bytes
     Name: Contrôleur hôte universel Intel(R) gamme ICH9 USB - 2935
Device ID: PCI\VEN_8086&DEV_2935&SUBSYS_11001AF4&REV_03\3&13C0B0C5&3&29
   Driver: C:\Windows\system32\drivers\usbuhci.sys, 10.00.14393.0000 (English), 7/16/2016 15:17:59, 35328 bytes
   Driver: C:\Windows\system32\drivers\usbport.sys, 10.00.14393.2339 (French), 6/12/2018 03:37:10, 453984 bytes
   Driver: C:\Windows\system32\drivers\usbhub.sys, 10.00.14393.1794 (French), 10/9/2017 04:37:27, 500576 bytes
     Name: Carte vidéo de base Microsoft
Device ID: PCI\VEN_1B36&DEV_0100&SUBSYS_11001AF4&REV_04\3&13C0B0C5&3&10
   Driver: n/a
     Name: Pont PCI vers ISA
Device ID: PCI\VEN_8086&DEV_7000&SUBSYS_11001AF4&REV_00\3&13C0B0C5&3&08
   Driver: C:\Windows\system32\DRIVERS\msisadrv.sys, 10.00.14393.0000 (English), 7/16/2016 15:18:03, 18784 bytes
     Name: Red Hat VirtIO Ethernet Adapter
Device ID: PCI\VEN_1AF4&DEV_1000&SUBSYS_00011AF4&REV_00\3&13C0B0C5&3&18
   Driver: C:\Windows\system32\DRIVERS\netkvm.sys, 100.76.0104.16000 (French), 8/3/2018 20:08:14, 138824 bytes
     Name: Contrôleur hôte universel Intel(R) gamme ICH9 USB - 2936
Device ID: PCI\VEN_8086&DEV_2936&SUBSYS_11001AF4&REV_03\3&13C0B0C5&3&2A
     Name: VirtIO Balloon Driver
Device ID: PCI\VEN_1AF4&DEV_1002&SUBSYS_00051AF4&REV_00\3&13C0B0C5&3&38
   Driver: C:\Windows\system32\DRIVERS\balloon.sys, 100.74.0104.14100 (French), 7/20/2017 04:46:00, 47176 bytes
     Name: Contrôleur hôte étendu Intel(R) gamme ICH9 USB2 - 293A
Device ID: PCI\VEN_8086&DEV_293A&SUBSYS_11001AF4&REV_03\3&13C0B0C5&3&2F
   Driver: C:\Windows\system32\drivers\usbehci.sys, 10.00.14393.0000 (French), 7/16/2016 15:17:59, 96096 bytes
     Name: Red Hat VirtIO SCSI pass-through controller
Device ID: PCI\VEN_1AF4&DEV_1004&SUBSYS_00081AF4&REV_00\3&13C0B0C5&3&48
   Driver: C:\Windows\system32\DRIVERS\vioscsi.sys, 100.74.0104.14100 (French), 7/20/2017 04:46:12, 43080 bytes
Device ID: PCI\VEN_1AF4&DEV_1004&SUBSYS_00081AF4&REV_00\3&13C0B0C5&3&40
     Name: VirtIO Serial Driver
Device ID: PCI\VEN_1AF4&DEV_1003&SUBSYS_00031AF4&REV_00\3&13C0B0C5&3&30
   Driver: C:\Windows\system32\DRIVERS\vioser.sys, 100.76.0104.16000 (French), 8/3/2018 20:08:18, 72264 bytes
     Name: Contrôleur High Definition Audio
Device ID: PCI\VEN_8086&DEV_2668&SUBSYS_11001AF4&REV_01\3&13C0B0C5&3&20
   Driver: C:\Windows\system32\DRIVERS\hdaudbus.sys, 10.00.14393.0000 (English), 7/16/2016 15:18:02, 83456 bytes
   Driver: C:\Windows\system32\DRIVERS\drmk.sys, 10.00.14393.0000 (English), 7/16/2016 15:18:02, 97280 bytes
   Driver: C:\Windows\system32\DRIVERS\portcls.sys, 10.00.14393.0000 (English), 7/16/2016 15:18:02, 366592 bytes
     Name: Contrôleur hôte universel Intel(R) gamme ICH9 USB - 2934
Device ID: PCI\VEN_8086&DEV_2934&SUBSYS_11001AF4&REV_03\3&13C0B0C5&3&28
     Name: Pont processeur vers PCI
Device ID: PCI\VEN_8086&DEV_1237&SUBSYS_11001AF4&REV_02\3&13C0B0C5&3&00
   Driver: n/a
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,10.00.14393.2248
WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,10.00.14393.2248
WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,10.00.14393.0000
MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,10.00.14393.0000
Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,10.00.14393.2248
WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,10.00.14393.0000
WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,10.00.14393.2608
Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,10.00.14393.0000
Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,10.00.14393.0000
DV Muxer,0x00400000,0,0,qdv.dll,10.00.14393.0000
Color Space Converter,0x00400001,1,1,quartz.dll,10.00.14393.2273
WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.14393.2035
AVI Splitter,0x00600000,1,1,quartz.dll,10.00.14393.2273
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,10.00.14393.2273
SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,10.00.14393.2848
Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,10.00.14393.2608
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,10.00.14393.2248
StreamBufferSink,0x00200000,0,0,sbe.dll,10.00.14393.2848
MJPEG Decompressor,0x00600000,1,1,quartz.dll,10.00.14393.2273
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,10.00.14393.2273
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,10.00.14393.2273
VBI Codec,0x00600000,1,4,VBICodec.ax,10.00.14393.2248
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,10.00.14393.2248
Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,10.00.14393.2248
SBE2FileScan,0x00200000,0,0,sbe.dll,10.00.14393.2848
Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,10.00.14393.2248
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,10.00.14393.2273
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,10.00.14393.2273
DV Splitter,0x00600000,1,2,qdv.dll,10.00.14393.0000
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,10.00.14393.2273
Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,10.00.14393.2248
ACM Wrapper,0x00600000,1,1,quartz.dll,10.00.14393.2273
Video Renderer,0x00800001,1,0,quartz.dll,10.00.14393.2273
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,10.00.14393.2848
Line 21 Decoder,0x00600000,1,1,,
Video Port Manager,0x00600000,2,1,quartz.dll,10.00.14393.2273
Video Renderer,0x00400000,1,0,quartz.dll,10.00.14393.2273
VPS Decoder,0x00200000,0,0,WSTPager.ax,10.00.14393.2248
WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.14393.2035
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,
File writer,0x00200000,1,0,qcap.dll,10.00.14393.2248
DVD Navigator,0x00200000,0,3,qdvd.dll,10.00.14393.2248
Overlay Mixer2,0x00200000,1,1,,
Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,10.00.14393.2248
WST Pager,0x00200000,1,1,WSTPager.ax,10.00.14393.2248
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,10.00.14393.2248
DV Video Decoder,0x00800000,1,1,qdv.dll,10.00.14393.0000
SampleGrabber,0x00200000,1,1,qedit.dll,10.00.14393.2608
Null Renderer,0x00200000,1,0,qedit.dll,10.00.14393.2608
MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,10.00.14393.2248
StreamBufferSource,0x00200000,0,0,sbe.dll,10.00.14393.2848
Smart Tee,0x00200000,1,2,qcap.dll,10.00.14393.2248
Overlay Mixer,0x00200000,0,0,,
AVI Decompressor,0x00600000,1,1,quartz.dll,10.00.14393.2273
AVI/WAV File Source,0x00400000,0,2,quartz.dll,10.00.14393.2273
Wave Parser,0x00400000,1,1,quartz.dll,10.00.14393.2273
MIDI Parser,0x00400000,1,1,quartz.dll,10.00.14393.2273
Multi-file Parser,0x00400000,1,1,quartz.dll,10.00.14393.2273
File stream renderer,0x00400000,1,1,quartz.dll,10.00.14393.2273
StreamBufferSink2,0x00200000,0,0,sbe.dll,10.00.14393.2848
AVI Mux,0x00200000,1,0,qcap.dll,10.00.14393.2248
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,10.00.14393.2273
File Source (Async.),0x00400000,0,1,quartz.dll,10.00.14393.2273
File Source (URL),0x00400000,0,1,quartz.dll,10.00.14393.2273
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,10.00.14393.2248
Enhanced Video Renderer,0x00200000,1,0,evr.dll,10.00.14393.2515
BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,10.00.14393.2248
MPEG Video Decoder,0x40000001,1,1,quartz.dll,10.00.14393.2273
WDM Streaming Tee/Splitter Devices:
Convertisseur en T/site-à-site,0x00200000,1,1,ksproxy.ax,10.00.14393.2273
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,10.00.14393.0000
WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,10.00.14393.0000
MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,10.00.14393.0000
DV Video Encoder,0x00200000,0,0,qdv.dll,10.00.14393.0000
MJPEG Compressor,0x00200000,0,0,quartz.dll,10.00.14393.2273
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,10.00.14393.2248
WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,10.00.14393.0000
IMA ADPCM,0x00200000,1,1,quartz.dll,10.00.14393.2273
Microsoft ADPCM,0x00200000,1,1,quartz.dll,10.00.14393.2273
GSM 6.10,0x00200000,1,1,quartz.dll,10.00.14393.2273
CCITT A-Law,0x00200000,1,1,quartz.dll,10.00.14393.2273
CCITT u-Law,0x00200000,1,1,quartz.dll,10.00.14393.2273
MPEG Layer-3,0x00200000,1,1,quartz.dll,10.00.14393.2273
PBDA CP Filters:
PBDA DTFilter,0x00600000,1,1,CPFilters.dll,10.00.14393.2848
PBDA ETFilter,0x00200000,0,0,CPFilters.dll,10.00.14393.2848
PBDA PTFilter,0x00200000,0,0,CPFilters.dll,10.00.14393.2848
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,10.00.14393.2273
Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,10.00.14393.2273
WDM Streaming Capture Devices:
Entrée de ligne HD Audio,0x00200000,1,1,ksproxy.ax,10.00.14393.2273
WDM Streaming Rendering Devices:
Haut-parleur HD Audio,0x00200000,1,1,ksproxy.ax,10.00.14393.2273
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.14393.2248
Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.14393.2248
Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.14393.2248
Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.14393.2248
Microsoft Network Provider,0x00200000,0,1,MSNP.ax,10.00.14393.2248
Multi-Instance Capable VBI Codecs:
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,10.00.14393.2248
MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,10.00.14393.2248
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,1,EncDec.dll,10.00.14393.2273
Encrypt/Tag,0x00200000,0,0,EncDec.dll,10.00.14393.2273
PTFilter,0x00200000,0,0,EncDec.dll,10.00.14393.2273
XDS Codec,0x00200000,0,0,EncDec.dll,10.00.14393.2273
WDM Streaming Communication Transforms:
Audio Renderers:
Sortie audio de l’ordinateur distant,0x00200000,1,0,quartz.dll,10.00.14393.2273
Default DirectSound Device,0x00800000,1,0,quartz.dll,10.00.14393.2273
Default WaveOut Device,0x00200000,1,0,quartz.dll,10.00.14393.2273
DirectSound: Sortie audio de l’ordinateur distant,0x00200000,1,0,quartz.dll,10.00.14393.2273
Preferred DirectShow Filters
[HKEY_LOCAL_MACHINE\Software\Microsoft\DirectShow\Preferred]
<media subtype GUID>, [<filter friendly name>, ]<filter CLSID>
MEDIASUBTYPE_MPEG1Payload, MPEG Video Decoder, CLSID_CMpegVideoCodec
MEDIASUBTYPE_MPEG1Packet, MPEG Video Decoder, CLSID_CMpegVideoCodec
MEDIASUBTYPE_MPEG2_VIDEO, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
{78766964-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{7634706D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_mp4s, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{6C737664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
{64737664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
{64697678-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{64687664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
{58564944-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{5634504D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_MP4S, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WMVR, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVP, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_MJPG, MJPEG Decompressor, CLSID_MjpegDec
{44495658-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WMVA, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mpg4, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MPG4, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_h264, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
MEDIASUBTYPE_H264, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
MEDIASUBTYPE_WMV3, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mp43, Mpeg43 Decoder DMO, CLSID_CMpeg43DecMediaObject
MEDIASUBTYPE_MP43, Mpeg43 Decoder DMO, CLSID_CMpeg43DecMediaObject
MEDIASUBTYPE_m4s2, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WMV2, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_MSS2, WMV Screen decoder DMO, CLSID_CMSSCDecMediaObject
MEDIASUBTYPE_M4S2, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WVP2, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mp42, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MP42, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_WMV1, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_MSS1, WMV Screen decoder DMO, CLSID_CMSSCDecMediaObject
MEDIASUBTYPE_WVC1, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_AVC1, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
{20637664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
MEDIASUBTYPE_WMAUDIO_LOSSLESS, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
MEDIASUBTYPE_WMAUDIO3, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
WMMEDIASUBTYPE_WMAudioV8, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
MEDIASUBTYPE_MSAUDIO1, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
WMMEDIASUBTYPE_MP3, MP3 Decoder DMO, CLSID_CMP3DecMediaObject
MEDIASUBTYPE_MPEG1AudioPayload, MPEG Audio Decoder, CLSID_CMpegAudioCodec
WMMEDIASUBTYPE_WMSP2, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
WMMEDIASUBTYPE_WMSP1, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms]
<category>:
  <transform friendly name>, <transform CLSID>, <flags>, [<merit>, ]<file name>, <file version>
Video Decoders:
  Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}, 0x1, msmpeg2vdec.dll, 10.00.14393.2608
  DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}, 0x1, mfdvdec.dll, 10.00.14393.0000
  Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT, 0x1, mp4sdecd.dll, 10.00.14393.2248
  Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT, 0x1, msmpeg2vdec.dll, 10.00.14393.2608
  WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject, 0x1, wmvsdecd.dll, 10.00.14393.0000
  WMVideo Decoder MFT, CLSID_CWMVDecMediaObject, 0x1, wmvdecod.dll, 10.00.14393.2608
  MJPEG Decoder MFT, {CB17E772-E1CC-4633-8450-5617AF577905}, 0x1, mfmjpegdec.dll, 10.00.14393.1066
  Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject, 0x1, mp43decd.dll, 10.00.14393.0000
  Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject, 0x1, mpg4decd.dll, 10.00.14393.0000
Video Encoders:
  H264 Encoder MFT, {6CA50344-051A-4DED-9779-A43305165E35}, 0x1, mfh264enc.dll, 10.00.14393.2248
  WMVideo8 Encoder MFT, CLSID_CWMVXEncMediaObject, 0x1, wmvxencd.dll, 10.00.14393.0000
  H263 Encoder MFT, {BC47FCFE-98A0-4F27-BB07-698AF24F2B38}, 0x1, mfh263enc.dll, 10.00.14393.0000
  WMVideo9 Encoder MFT, CLSID_CWMV9EncMediaObject, 0x1, wmvencod.dll, 10.00.14393.0000
  Microsoft MPEG-2 Video Encoder MFT, {E6335F02-80B7-4DC4-ADFA-DFE7210D20D5}, 0x2, msmpeg2enc.dll, 10.00.14393.2248
Video Effects:
  Frame Rate Converter, CLSID_CFrameRateConvertDmo, 0x1, mfvdsp.dll, 10.00.14393.0000
  Resizer MFT, CLSID_CResizerDMO, 0x1, vidreszr.dll, 10.00.14393.0000
  VideoStabilization MFT, {51571744-7FE4-4FF2-A498-2DC34FF74F1B}, 0x1, MSVideoDSP.dll, 10.00.14393.2848
  Color Control, CLSID_CColorControlDmo, 0x1, mfvdsp.dll, 10.00.14393.0000
  Color Converter MFT, CLSID_CColorConvertDMO, 0x1, colorcnv.dll, 10.00.14393.0000
Video Processor:
  Microsoft Video Processor MFT, {88753B26-5B24-49BD-B2E7-0C445C78C982}, 0x1, msvproc.dll, 10.00.14393.0351
Audio Decoders:
  MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E}, 0x1, MSAMRNBDecoder.dll, 10.00.14393.0000
  WMAudio Decoder MFT, CLSID_CWMADecMediaObject, 0x1, WMADMOD.DLL, 10.00.14393.2248
  Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT, 0x1, MSAudDecMFT.dll, 10.00.14393.0206
  A-law Wrapper MFT, {36CB6E0C-78C1-42B2-9943-846262F31786}, 0x1, mfcore.dll, 10.00.14393.2848
  GSM ACM Wrapper MFT, {4A76B469-7B66-4DD4-BA2D-DDF244C766DC}, 0x1, mfcore.dll, 10.00.14393.2848
  WMAPro over S/PDIF MFT, CLSID_CWMAudioSpdTxDMO, 0x1, WMADMOD.DLL, 10.00.14393.2248
  Microsoft Opus Audio Decoder MFT, {63E17C10-2D43-4C42-8FE3-8D8B63E46A6A}, 0x1, MSOpusDecoder.dll, 10.00.14393.0000
  Microsoft FLAC Audio Decoder MFT, {6B0B3E6B-A2C5-4514-8055-AFE8A95242D9}, 0x1, MSFlacDecoder.dll, 10.00.14393.2457
  Microsoft MPEG Audio Decoder MFT, {70707B39-B2CA-4015-ABEA-F8447D22D88B}, 0x1, MSAudDecMFT.dll, 10.00.14393.0206
  WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject, 0x1, WMSPDMOD.DLL, 10.00.14393.0000
  G711 Wrapper MFT, {92B66080-5E2D-449E-90C4-C41F268E5514}, 0x1, mfcore.dll, 10.00.14393.2848
  IMA ADPCM ACM Wrapper MFT, {A16E1BFF-A80D-48AD-AECD-A35C005685FE}, 0x1, mfcore.dll, 10.00.14393.2848
  MP3 Decoder MFT, CLSID_CMP3DecMediaObject, 0x1, mp3dmod.dll, 10.00.14393.0000
  Microsoft ALAC Audio Decoder MFT, {C0CD7D12-31FC-4BBC-B363-7322EE3E1879}, 0x1, MSAlacDecoder.dll, 10.00.14393.0000
  ADPCM ACM Wrapper MFT, {CA34FE0A-5722-43AD-AF23-05F7650257DD}, 0x1, mfcore.dll, 10.00.14393.2848
  Dolby TrueHD IEC-61937 converter MFT, {CF5EEEDF-0E92-4B3B-A161-BD0FFE545E4B}, 0x1, mfaudiocnv.dll, 10.00.14393.0479
  DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}, 0x1, mfaudiocnv.dll, 10.00.14393.0479
Audio Encoders:
  LPCM DVD-Audio MFT, {068A8476-9229-4CC0-9D49-2FC699DCD30A}, 0x1, mfaudiocnv.dll, 10.00.14393.0479
  MP3 Encoder ACM Wrapper MFT, {11103421-354C-4CCA-A7A3-1AFF9A5B6701}, 0x1, mfcore.dll, 10.00.14393.2848
  Microsoft FLAC Audio Encoder MFT, {128509E9-C44E-45DC-95E9-C255B8F466A6}, 0x1, MSFlacEncoder.dll, 10.00.14393.2457
  WM Speech Encoder DMO, CLSID_CWMSPEncMediaObject2, 0x1, WMSPDMOE.DLL, 10.00.14393.2248
  MS AMRNB Encoder MFT, {2FAE8AFE-04A3-423A-A814-85DB454712B0}, 0x1, MSAMRNBEncoder.dll, 10.00.14393.0000
  Microsoft MPEG-2 Audio Encoder MFT, {46A4DD5C-73F8-4304-94DF-308F760974F4}, 0x1, msmpeg2enc.dll, 10.00.14393.2248
  WMAudio Encoder MFT, CLSID_CWMAEncMediaObject, 0x1, WMADMOE.DLL, 10.00.14393.0000
  Microsoft AAC Audio Encoder MFT, {93AF0C51-2275-45D2-A35B-F2BA21CAED00}, 0x1, mfAACEnc.dll, 10.00.14393.0000
  Microsoft ALAC Audio Encoder MFT, {9AB6A28C-748E-4B6A-BFFF-CC443B8E8FB4}, 0x1, MSAlacEncoder.dll, 10.00.14393.0000
Audio Effects:
  AEC, CLSID_CWMAudioAEC, 0x1, mfwmaaec.dll, 10.00.14393.0000
  Resampler MFT, CLSID_CResamplerMediaObject, 0x1, resampledmo.dll, 10.00.14393.0000
Multiplexers:
  Microsoft MPEG2 Multiplexer MFT, {AB300F71-01AB-46D2-AB6C-64906CB03258}, 0x2, mfmpeg2srcsnk.dll, 10.00.14393.2608
Others:
  Microsoft H264 Video Remux (MPEG2TSToMP4) MFT, {05A47EBB-8BF0-4CBF-AD2F-3B71D75866F5}, 0x1, msmpeg2vdec.dll, 10.00.14393.2608
Media Foundation Enabled Hardware Categories
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\HardwareMFT]
Media Foundation Byte Stream Handlers
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\ByteStreamHandlers]
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\MediaSources\Preferred]
<file ext. or MIME type>, <handler CLSID>, <brief description>[, Preferred]
.3g2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.ac3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
.adt, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.adts, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.am?, {EFE6208A-0A2C-49FA-8A01-3768B559B6DA}, MF AMRNB Media Source ByteStreamHandler
.amr, {EFE6208A-0A2C-49FA-8A01-3768B559B6DA}, MF AMRNB Media Source ByteStreamHandler, Preferred
.asf, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.avi, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
.dvr-ms, {65964407-A5D8-4060-85B0-1CCD63F768E2}, dvr-ms Byte Stream Handler, Preferred
.dvr-ms, {A8721937-E2FB-4D7A-A9EE-4EB08C890B6E}, MF SBE Source ByteStreamHandler
.ec3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
.flac, {0E41CFB8-0506-40F4-A516-77CC23642D91}, MF FLAC Media Source ByteStreamHandler, Preferred
.m2t, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.m2ts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.m4a, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.m4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mk3d, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mka, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mks, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mkv, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mod, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mov, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mp2v, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
.mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mp4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mpa, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
.mpeg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mpg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.nsc, {B084785C-DDE0-4D30-8CA8-05A373E185BE}, NSC Byte Stream Handler, Preferred
.sami, {7A56C4CB-D678-4188-85A8-BA2EF68FA10D}, SAMI Byte Stream Handler, Preferred
.smi, {7A56C4CB-D678-4188-85A8-BA2EF68FA10D}, SAMI Byte Stream Handler, Preferred
.tod, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.ts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.tts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.uvu, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.vob, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
.wm, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wma, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wmv, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wtv, {65964407-A5D8-4060-85B0-1CCD63F768E2}, WTV Byte Stream Handler, Preferred
audio/3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/3gpp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/aacp, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/eac3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
audio/L16, {3FFB3B8C-EB99-472B-8902-E1C1B05F07CF}, LPCM Byte Stream Handler, Preferred
audio/mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/MP4A-LATM, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/mpa, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mpeg, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mpeg3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/vnd.dlna.adts, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/vnd.dolby.dd-raw, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
audio/wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
audio/x-aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/x-m4a, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/x-matroska, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
audio/x-mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/x-mpeg, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/x-ms-wma, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
audio/x-wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
video/3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/3gpp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/avi, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
video/mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/mpeg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
video/msvideo, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
video/vnd.dece.mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/vnd.dlna.mpeg-tts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
video/x-m4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/x-matroska, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
video/x-ms-asf, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-ms-wm, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-ms-wmv, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-msvideo, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
Media Foundation Scheme Handlers
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\SchemeHandlers]
<URL type>, <handler CLSID>, <brief description>[, Preferred]
file:, {477EC299-1421-4BDD-971F-7CCB933F21AD}, File Scheme Handler, Preferred
http:, {44CB442B-9DA9-49DF-B3FD-023777B16E50}, Http Scheme Handler
http:, {9EC4B4F9-3029-45AD-947B-344DE2A249E2}, Urlmon Scheme Handler
http:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
httpd:, {44CB442B-9DA9-49DF-B3FD-023777B16E50}, Http Scheme Handler, Preferred
httpnd:, {2EEEED04-0908-4CDB-AF8F-AC5B768A34C9}, Drm Scheme Handler, Preferred
https:, {37A61C8B-7F8E-4D08-B12B-248D73E9AB4F}, Secure Http Scheme Handler, Preferred
httpsd:, {37A61C8B-7F8E-4D08-B12B-248D73E9AB4F}, Secure Http Scheme Handler, Preferred
httpt:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
httpu:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
mcast:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
mcrecv:, {FA6D33D4-9405-4BA5-9983-12604AC8E77A}, Miracast Sink Scheme Handler, Preferred
mms:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
ms-appdata:, {CFC81939-3886-4ACF-9692-DA58037AE716}, MsAppData Scheme Handler, Preferred
ms-appx-web:, {8DB0224B-3D65-4F6F-8E12-BEB4B78B8974}, MsAppxWeb Scheme Handler, Preferred
ms-appx:, {8DB0224B-3D65-4F6F-8E12-BEB4B78B8974}, MsAppx Scheme Handler, Preferred
ms-winsoundevent:, {F79A6BF9-7415-4CF3-AE10-4559509ABC3C}, Sound Event Scheme Handler, Preferred
rtsp:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
rtspt:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
rtspu:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
sdp:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
Preferred Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms\Preferred]
<media subtype GUID>, [<transform friendly name>, ]<transform CLSID>
MFAudioFormat_AAC, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT
{00001600-0000-0100-0800-000aa00389b71}, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT
MEDIASUBTYPE_RAW_AAC1, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT
MFAudioFormat_MPEG, Microsoft MPEG Audio Decoder MFT, {70707B39-B2CA-4015-ABEA-F8447D22D88B}
{EB27CEC4-163E-4CA3-8B74-8E25F91B517E}, Dolby TrueHD IEC-61937 converter MFT, {CF5EEEDF-0E92-4B3B-A161-BD0FFE545E4B}
MFVideoFormat_MPEG2, Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}
{A2E58EB7-0FA9-48BB-A40C-FA0E156D0645}, DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}
{7634706D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
{73616D72-767A-494D-B478-F29D25DC9037}, MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E}
MEDIASUBTYPE_mp4s, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MFVideoFormat_DVSL, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
MFVideoFormat_DVSD, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
MFVideoFormat_DVHD, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
MFVideoFormat_MP4V, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MFVideoFormat_MP4S, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
{53314356-0000-0010-8000-00AA00389B71}, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVR, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVP, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_MJPG, MJPEG Decoder MFT, {CB17E772-E1CC-4633-8450-5617AF577905}
MEDIASUBTYPE_WMVA, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
{3F40F4F0-5622-4FF8-B6D8-A17A584BEE5E}, Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT
MEDIASUBTYPE_mpg4, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MPG4, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MFVideoFormat_H264, Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT
MFVideoFormat_WMV3, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
{33363248-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MEDIASUBTYPE_mp43, Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject
MFVideoFormat_MP43, Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject
MEDIASUBTYPE_m4s2, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MFVideoFormat_WMV2, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_MSS2, WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject
MFVideoFormat_M4S2, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MEDIASUBTYPE_WVP2, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mp42, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MP42, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MFVideoFormat_WMV1, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_MSS1, WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject
MFVideoFormat_MPG1, Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}
MFVideoFormat_WVC1, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_DVC, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
{0000F1AC-0000-0010-8000-00AA00389B71}, Microsoft FLAC Audio Decoder MFT, {6B0B3E6B-A2C5-4514-8055-AFE8A95242D9}
{00007361-0000-0010-8000-00AA00389B71}, MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E}
{0000704F-0000-0010-8000-00AA00389B71}, Microsoft Opus Audio Decoder MFT, {63E17C10-2D43-4C42-8FE3-8D8B63E46A6A}
{00006C61-0000-0010-8000-00AA00389B71}, Microsoft ALAC Audio Decoder MFT, {C0CD7D12-31FC-4BBC-B363-7322EE3E1879}
{00002001-0000-0010-8000-00AA00389B71}, DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}
MFAudioFormat_WMAudio_Lossless, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MFAudioFormat_WMAudioV9, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MFAudioFormat_WMAudioV8, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MEDIASUBTYPE_MSAUDIO1, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MFAudioFormat_MP3, MP3 Decoder MFT, CLSID_CMP3DecMediaObject
{00000031-0000-0010-8000-00AA00389B71}, GSM ACM Wrapper MFT, {4A76B469-7B66-4DD4-BA2D-DDF244C766DC}
{00000011-0000-0010-8000-00AA00389B71}, IMA ADPCM ACM Wrapper MFT, {A16E1BFF-A80D-48AD-AECD-A35C005685FE}
MFAudioFormat_MSP1, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
KSDATAFORMAT_SUBTYPE_MULAW, G711 Wrapper MFT, {92B66080-5E2D-449E-90C4-C41F268E5514}
{00000006-0000-0010-8000-00AA00389B71}, A-law Wrapper MFT, {36CB6E0C-78C1-42B2-9943-846262F31786}
KSDATAFORMAT_SUBTYPE_ADPCM, ADPCM ACM Wrapper MFT, {CA34FE0A-5722-43AD-AF23-05F7650257DD}
Disabled Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms\DoNotUse]
<transform CLSID>
Disabled Media Sources
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\MediaSources\DoNotUse]
<media source CLSID>
EVR Power Information
Current Setting: {5C67A112-A4C9-483F-B4A7-1D473BECAFDC} (Quality)
  Quality Flags: 2576
    Enabled:
    Force throttling
    Allow half deinterlace
    Allow scaling
    Decode Power Usage: 100
  Balanced Flags: 1424
    Enabled:
    Force throttling
    Allow batching
    Force half deinterlace
    Force scaling
    Decode Power Usage: 50
  PowerFlags: 1424
    Enabled:
    Force throttling
    Allow batching
    Force scaling
    Decode Power Usage: 0
Diagnostics
Windows Error Reporting:
+++ WER0 +++:
No Data
+++ WER1 +++:
No Data
+++ WER2 +++:
No Data
+++ WER3 +++:
No Data
+++ WER4 +++:
No Data
+++ WER5 +++:
No Data
+++ WER6 +++:
No Data
+++ WER7 +++:
No Data
+++ WER8 +++:
No Data
+++ WER9 +++:
No Data
Tags (3)
MichaelBranscomb
Esri Frequent Contributor
That error indicates a problem in our DirectX rendering code.
- Can you reproduce with the current release? (v100.5)
- Is this on your development machine?
- Are you able to reproduce on another machine?
- For the machine(s) on which this is reproducible - do they have up-to-date graphics drivers?
- Can you share a reproducer app/code that consistently shows this issue?
Cheers
Mike
This issue happens in production so I cant know if it's the same with the release 100.5.
The graphic driver looks up-to-date but the application run in RDP mode (16 users).
The map needs to draw a lot of layers (>40).
Could you do something to avoid the app crash ?
Thanks !
jcb
MichaelBranscomb
We made improvements in v100.5 to resolve a DirectX related crash - it's quite likely that this will resolve the crash you are seeing.
Cheers
Mike
豪友梁
Sorry ,But i still has these problem in v100.5。When I Rotate the Map,The System will Crashed And show  c:\daily_r\rtc\runtimecore\c_api\src\mapping\map_view\geo_view.cpp(205) : error : Exception caught in RT_GeoView_pulse
KyleGruber
It's great that ESRI may have this issue fixed for you, and I'm sure there's likely a reason that you're having to do this in the first place, but I have to say that running a WPF application in an RDP environment has just historically been a very bad experience.  You will see performance problems and crashes that you will never get running the app on the machine directly.  I would say if there's any way possible to find a way to get the app out of the RDP environment.
