Populating Datagrid with shapefile attributes, Runtime .NET SDK
3967
10-31-2014 07:11 AM
AdamRigel
I am trying to populate a data grid with the records from a shapefile or feature service.  However, when I set the shapefile/feature service to the item source for the datagrid, I only seem to get the metadata and not the attributes contained in the shapefile (i.e. I get three columns: 'Schema','Attributes','Geometry').  Does anybody know how I can get the attribute columns to populate the datagrid?  I am using the code below:
private async void QueryEQ_Click(object sender, RoutedEventArgs e)
    //Query the Earthquake layer for quakes with a magnitude greater than defined by the user
    var featureSvcTable = await Esri.ArcGISRuntime.Data.ServiceFeatureTable.OpenAsync(new Uri("http://igems.doi.gov/arcgis/rest/services/igems_haz/mapserver/3"));
    var query = new Esri.ArcGISRuntime.Data.QueryFilter();
    query.WhereClause = string.Format("magnitude  >= {0}",QueryIO.Text);
    var result = await featureSvcTable.QueryAsync(query);
   //Take query and populate graphics layer
    var gLayer = MyMapView.Map.Layers["EQs"] as GraphicsLayer;
    gLayer.Graphics.Clear();
    foreach (var f in result)
        var g = new Graphic(f.Geometry, f.Attributes);
        gLayer.Graphics.Add(g);
    //Add query result to the data grid table
    MyFeatureDataTable.ItemsSource = result;
