What happened to AGSWebTiledLayer in iOS and Android version 100 of the ArcGIS SDK?
2790
5
01-23-2017 04:31 PM
jefflutzenberger1
Anyone have sample code that consumes a /z/x/y.png layer?
YueWu1
by Esri Regular Contributor
Hi Jeff,
Current 100.0.0 Runtime hasn't implement the capability of using WebTiledLayer including (OpenStreetMap,WMS, WMTS, etc), for more detail information please check this online documentation:
Runtime Choosing the right version | ArcGIS for Developers
AdrianWelsh
MVP Honored Contributor
Jeff,
Which programming environment / language are you working in? I have seen similar examples to this in Leaflet.js:
Leaflet - a JavaScript library for interactive maps
Like:
var map = L.map('map').setView([51.505, -0.09], 13);
L.tileLayer('http://{s}.tile.osm.org/{z}/{x}/{y}.png', {
    attribution: '&copy; <a href="http://osm.org/copyright">OpenStreetMap</a> contributors'
}).addTo(map);
L.marker([51.5, -0.09]).addTo(map)
    .bindPopup('A pretty CSS3 popup.<br> Easily customizable.')
    .openPopup();
FC_Basson
If you are using the 3.19 API, have a look at WebTiledLayer | API Reference | ArcGIS API for JavaScript 3.19
with a nice example here: ArcGIS API for JavaScript Sandbox
jefflutzenberger1
Thanks. My bad for not being more specific. ArcGIS iOS and Android SDKs - the previous 10.x versions had that method. I don't see it in the new 100 version but I'm guessing there's a new way to do it?
AdrianWelsh
Jeff,
For better visibility, it might be best to move this thread to the https://community.esri.com/community/developers/native-app-developers/arcgis-runtime-sdk-for-ios?sr=...‌ place. Currently it's in the https://community.esri.com/community/help-and-feedback?sr=search&searchId=42de48eb-649d-4797-973e-ac...‌ place which is for help with the GeoNet.
YueWu1
Hi Jeff,
