Anyone have sample code that consumes a /z/x/y.png layer?
Hi Jeff,
Current 100.0.0 Runtime hasn't implement the capability of using WebTiledLayer including (OpenStreetMap,WMS, WMTS, etc), for more detail information please check this online documentation:
Runtime Choosing the right version | ArcGIS for Developers
Jeff,
Which programming environment / language are you working in? I have seen similar examples to this in Leaflet.js:
Leaflet - a JavaScript library for interactive maps
Like:
<SPAN class="keyword token">var</SPAN> map <SPAN class="operator token">=</SPAN> L<SPAN class="punctuation token">.</SPAN><SPAN class="token function">map</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'map'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">setView</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">51.505</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="operator token">-</SPAN><SPAN class="number token">0.09</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">13</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> L<SPAN class="punctuation token">.</SPAN><SPAN class="token function">tileLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token"><SPAN>'</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=http%3A%2F%2F" target="_blank">http://</A><SPAN>{s}.tile.osm.org/{z}/{x}/{y}.png'</SPAN></SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN> attribution<SPAN class="punctuation token">:</SPAN> <SPAN class="string token"><SPAN>'© <a href="</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=http%3A%2F%2Fosm.org%2Fcopyright" target="_blank">http://osm.org/copyright</A><SPAN>">OpenStreetMap</a> contributors'</SPAN></SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">addTo</SPAN><SPAN class="punctuation token">(</SPAN>map<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> L<SPAN class="punctuation token">.</SPAN><SPAN class="token function">marker</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">51.5</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="operator token">-</SPAN><SPAN class="number token">0.09</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">addTo</SPAN><SPAN class="punctuation token">(</SPAN>map<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">.</SPAN><SPAN class="token function">bindPopup</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'A pretty CSS3 popup.<br> Easily customizable.'</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">.</SPAN><SPAN class="token function">openPopup</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
If you are using the 3.19 API, have a look at WebTiledLayer | API Reference | ArcGIS API for JavaScript 3.19
with a nice example here: ArcGIS API for JavaScript Sandbox
Thanks. My bad for not being more specific. ArcGIS iOS and Android SDKs - the previous 10.x versions had that method. I don't see it in the new 100 version but I'm guessing there's a new way to do it?
For better visibility, it might be best to move this thread to the https://community.esri.com/community/developers/native-app-developers/arcgis-runtime-sdk-for-ios?sr=search&searchId=7836d195-d168-4696-803c-11cde9368f58&searchIndex=0 place. Currently it's in the https://community.esri.com/community/help-and-feedback?sr=search&searchId=42de48eb-649d-4797-973e-acba893d7612&searchIndex=0 place which is for help with the GeoNet.
