v2.3.2 and Local Tile Packages. Something is different.
1625
10
10-03-2012 09:21 AM
RussellShirley
Hi All,
I have been using the??? LocalTilePackage??? and ???GPS Sample??? sample codes merged together to do testing for a new app. Using version 2.2.1 the tile packages worked with the GPS perfect. When the Navigation and Compass Navigation modes were selected the GPS icons were centered on the screen. When I upgraded to version 2.3.2 they no longer are centered, they are to the left and bottom. This is true whether the app is on IOS 5.1 or 6.0, iPad or iPhone. I have even downloaded the latest sample code with the same results. So I must conclude that there is something different between the versions in relation to tile packages and GPS. FYI my WKID is 2239. My tile packages were created with Server 10.1 and Desktop 10.1
So has anyone come across this yet?
Thanks, Russell
RussellShirley
Nimesh,
The GPS info was correct. I had inadvertently set the position on the map within the XIB to values with negative numbers. So what I did was to move the map off-center of the view. The GPS went to the center of the map which was off center. Version 2.2.1 must have ignored my mistake and 2.3.2 did not. It was all dumb mistakes by a Xcode newbie. Thanks for all your responses and help.
Russell
