Upgrading to Version 2.3 of ArcGIS Runtime SDK for iOS
1153
7
07-06-2012 07:58 PM
c_f_ong
Hello
After upgrading to version 2.3, the help documentation doesn't seem to be upgraded as well in XCode. Anything else needs to be done for this to happen?
Also, I'm trying to configure the popup to allow for editing using the new approach as follows: (previous approach via AGSPopupInfo)
    // Show popup for graphic because user tapped on callout accessory button
    self.popupVC = [[AGSPopupsContainerViewController alloc] initWithPopupInfo:info graphic:graphic usingNavigationControllerStack:NO];
    self.popupVC.currentPopup.allowEdit = YES;
But it doesn't seem to work - Popup shows but doesn't allow editing! Any idea where's the problem?
Thanks.
Rgds
Ong CF
NimeshJarecha
Try doing this works?
AGSPopup *popup = [AGSPopup popupWithGraphic:graphic popupInfo:info];
popup.allowEdit = YES;
self.popupVC = [[[AGSPopupsContainerViewController alloc]initWithPopups:[NSArray arrayWithObject:popup]]autorelease];
Regards,
Nimesh
NimeshJarecha
Regards,
Nimesh
c_f_ong
Hi Nimesh
Thanks for your suggestion. I've tried it as follows for it to work.
    self.popupVC = [[AGSPopupsContainerViewController alloc] initWithPopups:[NSArray arrayWithObjects:popup, nil]];
Also, is the help documentation upgraded to match with changes in version 2.3?
Thanks.
Rgds
Ong CF
NimeshJarecha
Yes, here is the v2.3 documentation.
Regards,
Nimesh
c_f_ong
Hi Nimesh
Noted & thanks. However, the help documentation in Xcode doesn't seem to be updated as well to match with Version 2.3. Anyway, I'll just refer to the online documentation as suggested by you.
Best Regards
Ong CF
c_f_ong
Hi Nimesh
Just to probe further. If I load in a webmap (see below), then how do I set the popup to allow editing?
    self.popupVC = [[AGSPopupsContainerViewController alloc] initWithWebMap:self.webmap forFeature:graphic usingNavigationControllerStack:NO];
Thanks.
Rgds
Ong CF
NimeshJarecha
In case of web map, you should do it like this...
AGSPopupInfo *popupInfo = [self.webMap popupInfoForFeatureLayer:(AGSFeatureLayer*)graphic.layer];
AGSPopup *popup = [AGSPopup popupWithGraphic:graphic popupInfo:popupInfo];
self.popupVC = [[[AGSPopupsContainerViewController alloc]initWithPopups:[NSArray arrayWithObjectopup]]autorelease];
Regards,
Nimesh
c_f_ong
Hi Nimesh
Got it & thanks.
Rgds
Ong CF
