Map extent from zooms to smaller scale after executing a Predefined Search
893
05-10-2011 10:40 AM
MikeGregotski
I've created a Web Map in ArcGIS Explorer Online that contains some Queries.  I can then use these queries as Predefined searches in the out-of-the-box ArcGIS for iOS app (version 1.8.5).  This works great.
The problem I am having with the app is that when I select one of the results of the search my map zooms out to a smaller scale.  My map is of a building and the search does a search for rooms.  After I pick a result from my search it takes me from the extent of my building to an extent of several city blocks.  This is not how it works when the query is executed in ArcGIS Explorer Online
Does anyone know how the zoom can be suppresed or changed?
Here's the Web Map if you want to try for yourself in the ArcGIS for iOS app.
Thanks for any suggestions you might have.
Mike
