How to perform free style drawing on AGSMapview?
3136
6
01-28-2016 05:06 AM
Survey83Demo
I wanted to draw text(Free Style Drawing) on AGSMapview as annotation. Please suggest a way to do the same.
DiveshGoyal
AdrianWelsh
MVP Honored Contributor
Are you wanting this annotation to be saved later for others to see? Or just for you to see?
Using something like WebAppBuilder, you can utilize a Draw Widget that will allow you to draw shapes as well as text (annotation):
Draw widget—Web AppBuilder for ArcGIS | ArcGIS
DemoSurvey
We would like annotation to be persisted so that other can also see.
Thanks Adrain for your response. But I wanted to do free style drawing on AGSMapView for native iOS Application. Please let us know how to do the same on iOS?
Appreciate your help.
AdrianWelsh
I am not familiar with the AGSMapView for iOS. Hopefully someone on these boards can help.
MatthewBaber
If you aren't restricted to only AGSMapview: You could create an editable feature layer of a polyline shapefile. Make this the only editable layer and use Collector for ArcGIS or an ArcGIS Online Web App with editor tool. Collector will work with iOS (compatible with iOS 8 or later: Collector for ArcGIS | ArcGIS and the web app will work on any HTML5 browser.
DiveshGoyal
Survey83Demo
Thanks Divyesh for Reply... It works...
