How to disable transparency on AGSTiledMapServiceLayer.
3213
12-08-2015 07:35 AM
ilkerYILMAM
Hi Everyone
i'm beginner on this sdk.
My question is:
i'm using swift language
I have arcgis server tiled web service.Tile format is PNG
i'm adding this layer to my project.
But white colours are transparency.
how can i fix this.
Thanks
İmage Sample (road must be white)
and
Code Sample:
import UIKit
import ArcGIS
class ViewController: UIViewController, AGSMapViewLayerDelegate{
    @IBOutlet weak var mapView: AGSMapView!
    override func viewDidLoad() {
        super.viewDidLoad()
        let cred = AGSCredential(user: "userblabla", password: "pasblabla")
        let url = NSURL(string: "http://domain.compnay.com/arcgis/rest/services/layername/MapServer")
        let layer = AGSTiledMapServiceLayer(URL: url, credential: cred)
        layer.opacity=1
        self.mapView.addMapLayer(layer, withName: "Base")
        self.mapView.layerDelegate = self
    func mapViewDidLoad(mapView: AGSMapView!) {
        //do something now that the map is loaded
        //for example, show the current location on the map
        mapView.locationDisplay.startDataSource()
    override func didReceiveMemoryWarning() {
        super.didReceiveMemoryWarning()
        // Dispose of any resources that can be recreated.
ilkerYILMAM
Ok
I solved.
Solution:
  self.mapView.gridLineWidth=0
  self.mapView.backgroundColor=UIColor .whiteColor()
ilkerYILMAM
Ok
I solved.
Solution:
