Getting names and IDs of layers in an AGSDynamicMapServiceLayer
2788
5
07-06-2011 10:17 PM
RobertMartin2
I am trying to create an NSDictionary of layer names and IDs contained by an AGSDynamicMapServiceLayer. I've tried using the visibleLayers property, but the NSArray it returns is null. (I know this isn't the case, however, since my map view is being drawn correctly). Am I going about this the wrong way?
Thank you in advance,
Robert Martin
JeffPapirtis
See this thread I started.  It may do what you need.
http://forums.arcgis.com/threads/33344-Dynamic-Populating-list-of-available-Layers
This should return a dictionary of array's and then you can populate your array based on the key in the dictionary.
Jeff
NimeshJarecha
Robert,
All map service layers (Tiled and Dynamic) has property "mapServiceInfo" of type AGSMapServiceInfo. The AGSMapServiceInfo has layerInfos property which has all information of available layers in the map service and their default visibility as an array of AGSMapServiceLayerInfo objects.
You'll get IDs and Name of layer from AGSMapServiceLayerInfo.
Regards,
Nimesh
RobertMartin2
Thank you for the responses. @njarecha: Part of the problem may have been that I was trying to access the layers from mapViewDidLoad, but the dynamic service layer had not yet loaded. I tried adding an empty while loop to wait for the property 'loaded' to become true, but this seemed to prevent the map view from being displayed. I can't find any delegate methods for AGSDynamicMapServiceLayer... how are we supposed to know when it's loaded?
Thank you again,
Robert
NimeshJarecha
Robert,
You should use the AGSMapViewLayerDelegate's mapView:didLoadLayerForLayerView: method. This will fire for all the layers you are loading in the mapView. You can check the type of layer to be AGSDynamicMapServiceLayer and then build your sublayer list.
Hope this helps!
Regards,
Nimesh
RobertMartin2
That's perfect. Thank you!
