ArcGIS Polygon drawing issue with iPhone
5213
01-19-2015 12:39 PM
MuhammadHassan1
Hi,  I am new on ArcGIS iPhone platform. I have already developed a iPhone application, app was using MapKit framework for Overlays[Polylines and Polygons] drawing but due to some issues we are replacing Apple Maps SDK with ArcGIS IOS map. But I am getting few issues with ArcGIS IOS Maps.
1) I am trying to draw the Polygon Objects on ArcGIS map but its not appearing/drawing in correct shape and on correct location. On Apple map Polygons were drawing in Square shape but on ArcGIS iPhone Map polygons are showing as "Infinite Lines". [ I have attached the Output of ArcGIS Map and Apple Maps ]
## My Code
- (void)viewDidLoad {
    [super viewDidLoad];
    NSURL* url = [NSURL URLWithString:@"https://gis.zoetermeer.nl/arcgis/rest/services/Public/GBKZ_Prod/MapServer/"];
    AGSTiledMapServiceLayer *tiledLayer = [AGSTiledMapServiceLayer tiledMapServiceLayerWithURL:url];
    tiledLayer.delegate = self;
    [self.mapView addMapLayer:tiledLayer withName:@"Basemap Tiled Layer"];
- (void) layerDidLoad: (AGSLayer*) layer{
    NSLog(@"Layer added successfully");
        AGSGraphicsLayer* myGraphicsLayer = [AGSGraphicsLayer graphicsLayer];
        [self.mapView addMapLayer:myGraphicsLayer withName:@"Graphics Layer"];
        NSLog(@"%i",myGraphicsLayer.spatialReferenceStatusValid);
        AGSSpatialReference *specailRefference = [AGSSpatialReference spatialReferenceWithWKID: 28992];
        NSString *coordinateString = @"4.4998839821275 52.066336122032, 4.499855 52.066286, 4.499792 52.066176, 4.499696 52.066014, 4.499631 52.066002, 4.499611 52.065966, 4.499604 52.065862, 4.499448 52.065609, 4.499412 52.065552, 4.499407 52.065543, 4.499399 52.065536, 4.499389 52.065529, 4.499378 52.065524, 4.4993733686962 52.065522931238, 4.4993733686962 52.066336122032";
        NSString *coordinateString2 = @"4.4991002778594 52.065436800426, 4.499085 52.065422, 4.499100 52.065386, 4.499177 52.065316, 4.499370 52.065273, 4.499362 52.065259, 4.499053 52.065327, 4.498905 52.065360, 4.498794 52.065385, 4.498657 52.065415, 4.498647 52.065418, 4.498638 52.065423, 4.498632 52.065429, 4.498629 52.065436, 4.498629 52.065436800426";
        NSString *coordinateString3 = @"4.4993733686962 52.075329338091, 4.5008878063918 52.075329338091, 4.5008878063918 52.074430016486, 4.4993733686962 52.074430016486";
        AGSMutablePolygon *polyGon1 = [self getpolygon:coordinateString];
        AGSMutablePolygon *polyGon2 = [self getpolygon:coordinateString2];
        AGSMutablePolygon *polyGon3 = [self getpolygon:coordinateString3];
        CLLocationCoordinate2D coordinate = CLLocationCoordinate2DMake(52.066002,4.499631);
        AGSPoint* gpsPoint = [[AGSPoint alloc] initWithX:coordinate.longitude
                                                       y:coordinate.latitude
                                        spatialReference:[AGSSpatialReference wgs84SpatialReference]];
        AGSGeometryEngine* engine = [AGSGeometryEngine defaultGeometryEngine];
        AGSPoint* mapPoint = (AGSPoint*) [engine projectGeometry:gpsPoint
                                              toSpatialReference:specailRefference];
        [self.mapView zoomToGeometry:mapPoint withPadding:100 animated:YES];
        AGSGraphic *graphic1 = [[AGSGraphic alloc] initWithGeometry:polyGon1 symbol:[self barrierSymbol] attributes:nil];
        [myGraphicsLayer addGraphic:graphic1];
        AGSGraphic *graphic2 = [[AGSGraphic alloc] initWithGeometry:polyGon2 symbol:[self barrierSymbol]  attributes:nil];
        [myGraphicsLayer addGraphic:graphic2];
        AGSGraphic *graphic3 = [[AGSGraphic alloc] initWithGeometry:polyGon3 symbol:[self barrierSymbol]  attributes:nil];
        [myGraphicsLayer addGraphic:graphic3];
- (AGSCompositeSymbol*)barrierSymbol {
    AGSCompositeSymbol *cs = [AGSCompositeSymbol compositeSymbol];
    AGSSimpleLineSymbol *sls = [AGSSimpleLineSymbol simpleLineSymbol];
    sls.color = [UIColor greenColor];
    sls.style = AGSSimpleLineSymbolStyleSolid;
    sls.width = 20;
    AGSSimpleFillSymbol *sfs = [AGSSimpleFillSymbol simpleFillSymbol];
    sfs.outline = sls;
    sfs.style = AGSSimpleFillSymbolStyleHorizontal;
    sfs.color = [UIColor darkTextColor];
    [cs addSymbol:sfs];
    return cs;
-(AGSMutablePolygon*)getpolygon:(NSString*)coordinateString{
    AGSMutablePolygon *polyGon = [[AGSMutablePolygon alloc] initWithSpatialReference:specailRefference];
    [polyGon addRingToPolygon];
    NSArray *tokens = [coordinateString componentsSeparatedByString:@","];
    for (int k=0; k<[tokens count]; k++) {
        NSString *latlong = [tokens objectAtIndex:k];
        NSArray *latlongArray = [latlong componentsSeparatedByString:@" "];
        NSString *longi = [latlongArray objectAtIndex:0];
        double longVal = [longi doubleValue];
        NSString *lati = [latlongArray objectAtIndex:1];
        double latVal = [lati doubleValue];
        CLLocationCoordinate2D coordinate = CLLocationCoordinate2DMake(latVal, longVal);
        [polyGon addPointToRing:mapPoint];
    return polyGon;
GagandeepSingh
Hi Muhammad Hassan‌,
Thanks for sharing the code. It was helpful in debugging the problem.
After spending some time on this, I found out that the problem is with the way you have defined the coordinates in the NSString. There is an extra space after each comma (,), which causing zero value to be loaded for the latitude. So if you simply remove the extra spaces, this should work.
And you don't need to create CLLocationCoordinate2D coordinates. You can simply use the lat tong values for x and y when creating an AGSPoint.
Good luck!
GagandeepSingh
Good luck!
