AGSGDB generateGeodatabase fails (on large DBs?)
4852
06-03-2015 12:52 AM
KristofferStenersen
Yesterday new iOS-clients were no longer able to do initial AGSGDB-offline-sync with our AGS server.
Runtime SDK throws the following error upon generateGeodatabaseWithParameters:
Error Domain=NSURLErrorDomain Code=-1100 "The requested URL was not found on this server." UserInfo=0x174c77100 {NSErrorFailingURLStringKey=http://xxxxx/MapServer/_ags_data%7B7D7A28CBA33E44DC9939B255BA521B5E%7D.geodatabase?token=mSynh8LuH0j...,
I could not find too much of interest AGS server logs, but windows event viewer had an interesting entry:
  w3wp.exe
  IIS APPPOOL\ArcGISWebAdaptorAppPool
  ArithmeticException
  Overflow or underflow in the arithmetic operation.
  http://xxxxx/MapServer/_ags_data{E8151DFCCE0F4F22A34CF29C87D3DEAF}.geodatabase?token=mSynh8LuH0jBPn-...
  /arcgis/rest/directories/arcgisoutput/xxxxxMapServer/_ags_data{E8151DFCCE0F4F22A34CF29C87D3DEAF}.geodatabase
I did some testing and found that if I trimmed down the size of the initial sync-db by adding a filter to one of our feature classes (with a lot of large attachments), I was able to continue syncing. The arithmentic exception leads me to believe that this has to do with some variable getting an overflow storing the size of our offline gdb.
Thus, if this is a bug, it does not really belong in the Runtime SDK, it´s probably somewhere in the sync-tool on the server side - old clients are still able to sync - I don´t believe this is a client side issue.
I don´t have the exatct number on how large the db has become, but I believe it is in the 0.5-1GB range.
Kristoffer
DavidLednik
Hi Kristoffer,
Could you check the version of your arcgis server please.
regards,
David
KristofferStenersen
Hi David, thanks
Server version is 10.22.
MichaelDavis3
See this thread:
Collector App Sync - SEVERE ERROR.
Think you are experiencing the same bug.
DiveshGoyal
Have you tried installing the ArcGIS 10.2.2 for (Desktop, Engine, Server) Geodatabase and Feature Service Sync Optimization Patch ​ ? See if that helps.
Also, it looks like the server generated the geodatabase correctly, maybe the error occurs while trying to download it. Is IIS or the ArcGIS Web Adaptor having problems after serving out many geodatabases?To confirm this, you could try to manually get the geodatabase from the server machine's folder and put it on a client and see if it works.  When you do this, you will need to first enable the geodatabase for sync by manually calling AGSGDBSyncTask#registerSyncEnabledGeodatabase:​ on the client.
