unfortunately Routing task Sample has stopped
3610
12-11-2013 07:45 PM
davidgunawan1
like the title said, when i am trying to run sample code about routing task , the running process is going smoothly until the Android emu appears and shows "Unfortunately routing task sample has stopped"
[ATTACH=CONFIG]29791[/ATTACH]
and when i look into the log cat, it shows:
12-12 00:43:40.256: E/AndroidRuntime(809): FATAL EXCEPTION: main
12-12 00:43:40.256: E/AndroidRuntime(809): java.lang.UnsatisfiedLinkError: Couldn't load runtimecore_java from loader dalvik.system.PathClassLoader[DexPathList[[zip file "/data/app/com.esri.arcgis.android.samples.routing-1.apk"],nativeLibraryDirectories=[/data/app-lib/com.esri.arcgis.android.samples.routing-1, /system/lib]]]: findLibrary returned null
12-12 00:43:40.256: E/AndroidRuntime(809):  at java.lang.Runtime.loadLibrary(Runtime.java:355)
12-12 00:43:40.256: E/AndroidRuntime(809):  at java.lang.System.loadLibrary(System.java:525)
12-12 00:43:40.256: E/AndroidRuntime(809):  at com.esri.core.internal.util.e$1.initialize(Unknown Source)
12-12 00:43:40.256: E/AndroidRuntime(809):  at com.esri.core.geometry.GeometryEngine.a(Unknown Source)
12-12 00:43:40.256: E/AndroidRuntime(809):  at com.esri.core.geometry.GeometryEngine.<clinit>(Unknown Source)
12-12 00:43:40.256: E/AndroidRuntime(809):  at com.esri.core.geometry.SpatialReference.<clinit>(Unknown Source)
12-12 00:43:40.256: E/AndroidRuntime(809):  at com.esri.arcgis.android.samples.routing.RoutingSample.<init>(RoutingSample.java:86)
12-12 00:43:40.256: E/AndroidRuntime(809):  at java.lang.Class.newInstanceImpl(Native Method)
12-12 00:43:40.256: E/AndroidRuntime(809):  at java.lang.Class.newInstance(Class.java:1130)
12-12 00:43:40.256: E/AndroidRuntime(809):  at android.app.Instrumentation.newActivity(Instrumentation.java:1061)
12-12 00:43:40.256: E/AndroidRuntime(809):  at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:2128)
12-12 00:43:40.256: E/AndroidRuntime(809):  at android.app.ActivityThread.handleLaunchActivity(ActivityThread.java:2261)
12-12 00:43:40.256: E/AndroidRuntime(809):  at android.app.ActivityThread.access$600(ActivityThread.java:141)
12-12 00:43:40.256: E/AndroidRuntime(809):  at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1256)
12-12 00:43:40.256: E/AndroidRuntime(809):  at android.os.Handler.dispatchMessage(Handler.java:99)
12-12 00:43:40.256: E/AndroidRuntime(809):  at android.os.Looper.loop(Looper.java:137)
12-12 00:43:40.256: E/AndroidRuntime(809):  at android.app.ActivityThread.main(ActivityThread.java:5103)
12-12 00:43:40.256: E/AndroidRuntime(809):  at java.lang.reflect.Method.invokeNative(Native Method)
12-12 00:43:40.256: E/AndroidRuntime(809):  at java.lang.reflect.Method.invoke(Method.java:525)
12-12 00:43:40.256: E/AndroidRuntime(809):  at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:737)
12-12 00:43:40.256: E/AndroidRuntime(809):  at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:553)
12-12 00:43:40.256: E/AndroidRuntime(809):  at dalvik.system.NativeStart.main(Native Method)
any idea how to solve it? all the process from installing the Apk is success , but when it open the app, program stopped...
ErwinSoekianto
Esri Alum
What emulator are you running? what Android API level?
Please check if you have "libs" folder in your project and contains "armeabi" and "armeabi-v7a" in there
davidgunawan1
API level 18, Android Emulator im using now.
So i just copy the Armeabi and v7a folder to the libs?
davidgunawan1
okay, after i got the program running, now when i want to route a map, this notifications shows up
[ATTACH=CONFIG]29855[/ATTACH]
what else is this?
ErwinSoekianto
Esri Alum
Can you show us the network analyst rest end point used?
