Spatialite for Android studio
6898
02-11-2015 03:12 AM
TeroRönkkö
has someone succesfully added Spatialite libraries to Adroid studio project? All the guides so far explain Eclipse and state building spatialite with windows is hard or currently impossible.
All the help is appreciated!
This is my latest problem as I tried to import spatilite project as module:
Error:Execution failed for task ':spatialiteandroidlibrary:compileReleaseNdk'.
> java.io.IOException: Cannot run program "C:\Koodi\Android\Kapalo\spatialiteandroidlibrary\src\main\jniLibs\ndk-build.cmd": CreateProcess error=2, The system cannot find the file specified
TeroRönkkö
Actually solved this myself.
  1. Import Spatialite (prebuild solution for eclipse) as library project to android studio
  2. Make reference from main app to spatilite
    1. Make sure main project build.Grade of contains: compile project(':spatialiteandroidlibrary')
  3. In spatilitelibrary section make sure build.gradle contains:
       sourceSets.main {
             jniLibs.srcDir 'src/main/jniLibs'
             jni.srcDirs = []
The last jni.srcDirs disables autobuild of the so files and will instead use prebuilt ones.
TeroRönkkö
       sourceSets.main {
             jni.srcDirs = []
