java.util.concurrent.ExecutionException: com.esri.arcgisruntime.ArcGISRuntimeException: Invalid call.: Object failed to load, unable to execute task.
2946
04-18-2021 10:48 AM
EslamMostafaSayed
Hello all,
I'm trying to get the route data using the below code and getting the following error
  private fun findRoute() {
    // generate a route with directions and stops for navigation
    val routeTask = RouteTask(context, BuildConfig.ARC_GIS_ROUTING_URL)
    val routeParametersFuture = routeTask.createDefaultParametersAsync()
    routeParametersFuture.addDoneListener {
      // define the route parameters
      val routeParameters = routeParametersFuture.get().apply {
          try {
            val routeStops = listOf(
              // Destination stop
              Stop(Point(longitude, latitude, SpatialReferences.getWgs84()))
            setStops(routeStops)
            isReturnDirections = true
            isReturnStops = true
            isReturnRoutes = true
          } catch (e: Exception) {
            when (e) {
              is InterruptedException, is ExecutionException -> {
                val error = "Error getting the default route parameters: " + e.message
                Toast.makeText(activity, error, Toast.LENGTH_LONG)
                  .show()
                Log.e(TAG, error)
              else -> throw e
      val routeResultFuture = routeTask.solveRouteAsync(routeParameters)
      routeResultFuture.addDoneListener {
        try {
          // get the route geometry from the route result
          val routeResult = routeResultFuture.get()
          val routeGeometry = routeResult.routes[0].routeGeometry
          // create a graphic for the route geometry
          val routeGraphic = Graphic(
            routeGeometry,
            SimpleLineSymbol(SimpleLineSymbol.Style.SOLID, Color.BLUE, 5f)
          // add it to the graphics overlay
          binding.acceptMissionMapView.graphicsOverlays[0].graphics.add(routeGraphic)
          // set the map view view point to show the whole route
          binding.acceptMissionMapView.setViewpointAsync(Viewpoint(routeGeometry.extent))
          this.routeTask = routeTask
          this.routeResult = routeResult
          this.routeParameters = routeParameters
          when (e) {
              val error = "Error creating the route result: " + e.message
              Toast.makeText(context, error, Toast.LENGTH_LONG)
                .show()
              Log.e(TAG, error)
            else -> throw e
and this is the error that I'm getting:
2021-04-18 21:00:48.170 7991-7991/com.jst.poc.dispatcher E/AndroidRuntime: FATAL EXCEPTION: main     Process: com.jst.poc.dispatcher, PID: 7991     java.lang.RuntimeException: java.lang.reflect.InvocationTargetException         at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:602)         at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:947)      Caused by: java.lang.reflect.InvocationTargetException         at java.lang.reflect.Method.invoke(Native Method)         at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:592)         at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:947)      Caused by: java.util.concurrent.ExecutionException: com.esri.arcgisruntime.ArcGISRuntimeException: Invalid call.: Object failed to load, unable to execute task.         at com.esri.arcgisruntime.internal.c.b.get(SourceFile:130)         at com.jst.poc.dispatcher.features.dashboard.ui.fragments.AcceptMissionFragment$findRoute$1.run(AcceptMissionFragment.kt:186)         at android.os.Handler.handleCallback(Handler.java:938)         at android.os.Handler.dispatchMessage(Handler.java:99)         at android.os.Looper.loop(Looper.java:223)         at android.app.ActivityThread.main(ActivityThread.java:7656)         at java.lang.reflect.Method.invoke(Native Method)         at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:592)         at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:947)      Caused by: com.esri.arcgisruntime.ArcGISRuntimeException: Invalid call.: Object failed to load, unable to execute task.         at com.esri.arcgisruntime.internal.c.b.get(SourceFile:122)         at com.jst.poc.dispatcher.features.dashboard.ui.fragments.AcceptMissionFragment$findRoute$1.run(AcceptMissionFragment.kt:186)         at android.os.Handler.handleCallback(Handler.java:938)         at android.os.Handler.dispatchMessage(Handler.java:99)         at android.os.Looper.loop(Looper.java:223)         at android.app.ActivityThread.main(ActivityThread.java:7656)         at java.lang.reflect.Method.invoke(Native Method)         at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:592)         at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:947)
RamaChintapalli
Whats the version of Runtime SDK you are using? Were you able to execute this find-route sample,
https://github.com/Esri/arcgis-runtime-samples-android/tree/main/kotlin/find-route
Rama
