im devoloping arcgis android application i want to connect to postgre sql ,plz help me how to connect ..
3646
12-29-2015 02:51 AM
tulasamirji1
plz help me
ArtemisFili
You can create a service that references data from the postgre database and then use this service in your Android application.
Please take a look in the documentation below for the supported geodatabase formats
Supported geodatabase formats—ArcGIS Runtime SDK for .NET | ArcGIS for Developers
ArtemisFili
tulasamirji1
im beginner to android plz suggest me sum more examples.
ArtemisFili
Feel free to take a look at the following.
Access feature data in the cloud—ArcGIS Runtime SDK for Android | ArcGIS for Developers
You can just replace the url to the feature service with your feature service that will point to a postgre database.
Also the following might be helpful for starting with ArcGIS API for Android
Hello World - This is the most basic sample
arcgis-runtime-samples-android/HelloWorld at master · Esri/arcgis-runtime-samples-android · GitHub
Sample Code - This is a document that describes how to access all our Android samples
Android Sample Code Home | ArcGIS for Developers
