I tried to use the new SketchEditor. There's not much info on it beside the API doc, so here's my code:
if (viewerModel.getMapView().getSketchEditor() == null) {SketchEditor sketch =
new SketchEditor();
viewerModel.getMapView().setSketchEditor(sketch);
sketch.start(SketchCreationMode.
FREEHAND_LINE);
} else {
viewerModel.getMapView().getSketchEditor().stop();
viewerModel.getMapView().setSketchEditor(null);
}When I start the freehand sketch, the map pan with my movement so the line created is barely moving. I tried to overide the map onTouchListener onScroll , but it seems the SketchEditor is already doing that. There's probably another step I need to make I guess?
Can you help?
