how is create offline editor map and change orginal map Android ?
1553
08-08-2016 05:27 AM
CanDAGDELEN1
Tags (1)
AlexanderNohe1
Honored Contributor
Hello Can DAGDELEN
I believe that you may find this sample of some use to you:
Create Local Runtime Geodatabase | ArcGIS for Developers
This shows how to create an offline geodatabase to be used in a local mapping application.  You can find more of ArcGIS Runtime for Android samples here:
Android Sample Code Home | ArcGIS for Developers
I hope this helps!
