How do i check on Android if GeodatabaseFeatureTable supports Attchaments
2437
09-20-2016 12:34 PM
TércyoStorck1
How do i check on Android if GeodatabaseFeatureTable supports Attchaments?
TércyoStorck1
I've found why it awalys returns 'false'. I do not set GenerateGeodatanaseParameters.setReturnAttachments() to true. When I change it to true, it works fine.
Thanks!!
AlexanderNohe1
Honored Contributor
From the API reference:
public boolean GeodatabaseFeatureTable.hasAttachments()
Returns true if the table supports attachments.
Returns
  • true if the table supports attachments, false otherwise.
GeodatabaseFeatureTable | ArcGIS Android 10.2.8 API
I hope this helps!
TércyoStorck1
I saw it. But it's always return false... even when GeodatabaseFeatureTable supports attachments
AlexanderNohe1
Honored Contributor
Which version are you working with?
I can test in-house to see if I can reproduce.
TércyoStorck1
TércyoStorck1
Thanks!!
