How can I connect in a different ArcGIS Portal virtual directory via Android?
915
07-07-2017 09:06 AM
ViniciusCarvalho
Hello guys,
I'm having a trouble when I try to authenticate (via Android) in the ArcGIS Portal.
I've changed the ArcGIS Portal default directory. Switched "MY_PORTAL_URL/arcgis/home" to "MY_PORTAL_URL/portal/home/". But when I try to access the ArcGIS Portal (using com.esri.android.oauth.OAuthView) to auth the user, its returns the page below:
How can I solve this issue? Any ideas?
Thanks
GuthierryAlmeida
Try to use only "MY_PORTAL_URL/portal". Remember to register your application with Portal: How To: Add Collector for ArcGIS (Windows) as a registered application to Portal for ArcGIS 10.3.1 (In step 16, change the App ID to your Application Client ID).
Vlw! Flws!
GuthierryAlmeida
Vlw! Flws!
