help with displaying popups on map features in app?
8314
10
10-23-2017 11:00 AM
CoraColeman
Below is my current implementation of this method for displaying popups from the latest ArcGIS Runtime for Android SDK, however I have come to a stopping point where you see below:
 showPopup(identifiedPopup, screenPoint);
While I have been able to print out popups to the logcat console, I am still unsure how to go about actually configuring their display in my app past this info? I am getting a bit confused looking at the API code for popups here, and am wondering if I need to use the methods mentioned there in order to do this after I grab the popup from my layer?
import android.content.Context;
import android.support.v7.app.AppCompatActivity;
import android.os.Bundle;
import android.util.Log;
import android.view.MotionEvent;
import com.esri.arcgisruntime.concurrent.ListenableFuture;
import com.esri.arcgisruntime.data.Feature;
import com.esri.arcgisruntime.layers.FeatureLayer;
import com.esri.arcgisruntime.mapping.ArcGISMap;
import com.esri.arcgisruntime.mapping.GeoElement;
import com.esri.arcgisruntime.mapping.popup.Popup;
import com.esri.arcgisruntime.mapping.view.DefaultMapViewOnTouchListener;
import com.esri.arcgisruntime.mapping.view.IdentifyLayerResult;
import com.esri.arcgisruntime.mapping.view.MapView;
import com.esri.arcgisruntime.portal.Portal;
import com.esri.arcgisruntime.portal.PortalItem;
import java.util.List;
import java.util.concurrent.ExecutionException;
import static com.example.corac.generalglacier.R.id.mapView;
public class MainActivity extends AppCompatActivity {
    private Portal aPortal;
    private PortalItem aPortalItem;
    private ArcGISMap aMap;
    private MapView aMapView;
    @Override
    protected void onCreate(Bundle savedInstanceState) {
        super.onCreate(savedInstanceState);
        setContentView(R.layout.activity_main);
        // inflate MapView from layout
        aMapView = (MapView) findViewById(mapView);
        // get the portal url for ArcGIS Online
        aPortal = new Portal(getResources().getString(R.string.portal_url));
        // get the pre-defined portal id and portal url
        aPortalItem = new PortalItem(aPortal, getResources().getString(R.string.webmap_glacier_national_park_id));
        // create a map from a PortalItem
        aMap = new ArcGISMap(aPortalItem);
        // set the map to be displayed in this view
        aMapView.setMap(aMap);
        Log.d("MAP SET", "we have set our map!");
        aMapView.setOnTouchListener(new IdentifyFeatureLayerTouchListener(this, aMapView));
        Log.d("ID SET", "we have set our map to be identified!");
class IdentifyFeatureLayerTouchListener extends DefaultMapViewOnTouchListener {
    // provide a default constructor
    public IdentifyFeatureLayerTouchListener(Context context, MapView mapView) {
        super(context, mapView);
    // override the onSingleTapConfirmed gesture to handle a single tap on the MapView
    @Override
    public boolean onSingleTapConfirmed(MotionEvent e) {
        // reference to the layer to identify features in
        FeatureLayer layer = null;
        // get the screen point where user tapped
        final android.graphics.Point screenPoint = new android.graphics.Point((int) e.getX(), (int) e.getY());
        // call identifyLayersAsync, passing in the screen point, tolerance, return types, and maximum results, but no layer
        final ListenableFuture<List<IdentifyLayerResult>> identifyFuture = mMapView.identifyLayersAsync(
                screenPoint, 10, false);
        // add a listener to the future
        identifyFuture.addDoneListener(new Runnable() {
            @Override
            public void run() {
                try {
                    // get the identify results from the future - returns when the operation is complete
                    List<IdentifyLayerResult> identifyLayersResults = identifyFuture.get();
                    // Here we just show the pop-up for the first (top) layer; if more than one layer may have pop-ups, or more
                    // than one element is identified in a single layer, add controls to the pop-up content to iterate through
                    // multiple pop-ups.
                    if (identifyLayersResults.size() >= 1) {
                        IdentifyLayerResult identifyLayerResult = identifyLayersResults.get(0);
                        // Only identifying the topmost item in this example, so only expecting one pop-up
                        if (identifyLayerResult.getPopups().size() >= 1) {
                            Popup identifiedPopup = identifyLayerResult.getPopups().get(0);
                            Log.d("popup", identifiedPopup.toString());
                } catch (InterruptedException | ExecutionException ex) {
                    // deal with exceptions thrown from the async identify operation
        return true;
Tags (4)
CoraColeman
Hello, here is the code that worked for me, I followed the feature-layer-show-attributes sample exactly, only implementing it for two layers instead of one:
    // existing map references
    private LocationDisplay mLocationDisplay;
    private Spinner mSpinner;
    // request codes from Android
    private int requestCode = 2;
    String[] reqPermissions = new String[]{Manifest.permission.ACCESS_FINE_LOCATION, Manifest.permission
            .ACCESS_COARSE_LOCATION};
    // popups
    private Callout aCallout;
    private ServiceFeatureTable table0, table1;
    // private static final String sTag = "Gesture";
@Override
    // get the Spinner from layout
    mSpinner = (Spinner) findViewById(R.id.spinner);
    final ArcGISMap map = new ArcGISMap(Basemap.Type.DARK_GRAY_CANVAS_VECTOR, 48.6596, -113.7870, 9);
    aMapView.setMap(map);
    // get the callout that shows attributes
    aCallout = aMapView.getCallout();
    // layer 0, facilities
    table0 = new ServiceFeatureTable(getResources().getString(R.string.layer0_url));
    FeatureLayer featureLayer0 = new FeatureLayer(table0);
    map.getOperationalLayers().add(featureLayer0);
    // layer 1, trails
    table1 = new ServiceFeatureTable(getResources().getString(R.string.layer1_url));
    FeatureLayer featureLayer1 = new FeatureLayer(table1);
    map.getOperationalLayers().add(featureLayer1);
    // set an on touch listener to listen for click events
    aMapView.setOnTouchListener(new DefaultMapViewOnTouchListener(this, aMapView) {
        @Override
            // remove any existing callouts
            if (aCallout.isShowing()) {
                aCallout.dismiss();
            // get the point that was clicked and convert it to a point in map coordinates
            final Point clickPoint = aMapView.screenToLocation(new android.graphics.Point(Math.round(e.getX()), Math.round(e.getY())));
            // create a selection tolerance
            int tolerance = 10;
            double mapTolerance = tolerance * aMapView.getUnitsPerDensityIndependentPixel();
            // use tolerance to create an envelope to query
            Envelope envelope = new Envelope(clickPoint.getX() - mapTolerance, clickPoint.getY() - mapTolerance, clickPoint.getX() + mapTolerance, clickPoint.getY() + mapTolerance, map.getSpatialReference());
            QueryParameters query = new QueryParameters();
            query.setGeometry(envelope);
            // request all available attribute fields
            final ListenableFuture<FeatureQueryResult> future_0 = table0.queryFeaturesAsync(query, ServiceFeatureTable.QueryFeatureFields.LOAD_ALL);
            final ListenableFuture<FeatureQueryResult> future_1 = table1.queryFeaturesAsync(query, ServiceFeatureTable.QueryFeatureFields.LOAD_ALL);
            //print all available attr fields in logcat
            System.out.println(future_0.toString());
            Log.d("FUTURE0", "see ^");
            // example return: com.esri.arcgisruntime.data.ServiceFeatureTable$4@36c3a76
            System.out.println(future_1.toString());
            Log.d("FUTURE1", "see ^");
            // add done loading listener to fire when the selection returns
            future_0.addDoneListener(new Runnable() {
                @Override
                public void run() {
                    try {
                        //call get on the future to get the result
                        FeatureQueryResult result = future_0.get();
                        // create an Iterator
                        Iterator<Feature> iterator = result.iterator();
                        // create a TextView to display field values
                        TextView calloutContent = new TextView(getApplicationContext());
                        calloutContent.setTextColor(Color.BLACK);
                        calloutContent.setSingleLine(false);
                        calloutContent.setVerticalScrollBarEnabled(true);
                        calloutContent.setScrollBarStyle(View.SCROLLBARS_INSIDE_INSET);
                        calloutContent.setMovementMethod(new ScrollingMovementMethod());
                        calloutContent.setLines(5);
                        // cycle through selections
                        int counter = 0;
                        Feature feature;
                        while (iterator.hasNext()) {
                            feature = iterator.next();
                            // create a Map of all available attributes as name value pairs
                            Map<String, Object> attr = feature.getAttributes();
                            Set<String> keys = attr.keySet();
                            for (String key : keys) {
                                Object value = attr.get(key);
                                // format observed field value as date
                                if (value instanceof GregorianCalendar) {
                                    SimpleDateFormat simpleDateFormat = new SimpleDateFormat("dd-MMM-yyyy", Locale.US);
                                    value = simpleDateFormat.format(((GregorianCalendar) value).getTime());
                                //don't append the null ones
                                if(value.toString() != null | value.toString() != "" | value.toString() != "null") {
                                    // append name value pairs to TextView
                                    calloutContent.append(key + " | " + value + "\n");
                            counter++;
                            // center the mapview on selected feature
                            Envelope envelope = feature.getGeometry().getExtent();
                            aMapView.setViewpointGeometryAsync(envelope, 200);
                            // show CallOut
                            aCallout.setLocation(clickPoint);
                            aCallout.setContent(calloutContent);
                            aCallout.show();
                    } catch (Exception e) {
                        Log.e(getResources().getString(R.string.app_name), "Select feature failed: " + e.getMessage());
            future_1.addDoneListener(new Runnable() {
                @Override
                public void run() {
                    try {
                        FeatureQueryResult result = future_1.get();
                        int counter = 0;
                        Feature feature;
                            counter++;
                            // show CallOut
                            aCallout.show();
            return super.onSingleTapConfirmed(e);
@Override
public void onRequestPermissionsResult(int requestCode, @NonNull String[] permissions, @NonNull int[] grantResults) {
    // If request is cancelled, the result arrays are empty.
    if (grantResults.length > 0 && grantResults[0] == PackageManager.PERMISSION_GRANTED) {
        // Location permission was granted. This would have been triggered in response to failing to start the
        // LocationDisplay, so try starting this again.
        mLocationDisplay.startAsync();
    } else {
        // If permission was denied, show toast to inform user what was chosen. If LocationDisplay is started again,
        // request permission UX will be shown again, option should be shown to allow never showing the UX again.
        // Alternative would be to disable functionality so request is not shown again.
        Toast.makeText(MainActivity.this, getResources().getString(R.string.location_permission_denied), Toast
                .LENGTH_SHORT).show();
        // Update UI to reflect that the location display did not actually start
        mSpinner.setSelection(0, true);
@Override
protected void onPause() {
    super.onPause();
    aMapView.pause();
@Override
protected void onResume() {
    super.onResume();
    aMapView.resume();
AlexanderNohe1
Honored Contributor
Hi coracoleman14‌,
What is the showPopup() method that you have?
I do not see it in the code you provided above.
Alexander
CoraColeman
Hi, Thank you very much for your response! I am asking for help with writing the showPopup() method since I'm unsure how to proceed since there is no defined showPopup() method in the sample I'm following.
AlexanderNohe1
Honored Contributor
Ahh, okay. I believe the showPopup() method is left blank on purpose as there is a lot of different ways that a developer could implement this and more than likely, it is left up to the developers design and preference for their applications implementation.
I guess we need to break it down into how do you want to display your popups and specific behavior that you are looking for in order to move forward.  The popups can be displayed either as a separate view entirely or in a callout (think similar to ArcGIS Online).  What do you envision as the way you are interested in showing the popup?
Then, you would need to determine if you want to show attachments and media within the popups and determine how you would like to display this (again separate view or in the callout).
The code that is displayed above will only show the top selected element that is returned from the popups, this means that if you have multiple features sitting very close to each other (nearly on top of each other if not sitting on top of each other) when clicked will only return one feature.  Would you want to handle having multiple features showing?  And this again would require some thought on how to handle this.  (Perhaps a dialog with a recyclerview).
What type of features are you going to support? (MapServices, FeatureServices, Both?)  Are you supporting all webmaps or do you have a specific webmap in mind?
When the above is determined, we can perhaps provide a few pointers in the direction to go with this (along with some small snippets of code).
Did you have a look at my sample that I wrote a couple of months ago?  ( GitHub - nohe427/KtPopup: Kotlin Popups  )
This is written in Kotlin which is a bit different than Java, but the work involved to get rolling should be similar.  Are you familiar with Kotlin?  In this sample, I used the umano AndroidSlidingUpPanel (GitHub - umano/AndroidSlidingUpPanel: This library provides a simple way to add a draggable sliding ... ) to display my popups.  This was quite a challenge getting everything working correctly and is not something that comes out of the box from the SDK.  Since we last talked, I did bring it up to the SDK team that you are interested in seeing a function added for default behavior.
CoraColeman
Hello, thank you so much for your response! This I found to be very helpful in thinking about how I want to do the following:
I would want to display popups in a Callout - similar to ArcGIS Online.
I wouldn't want to support media (yet) but am interested in how I would go about for example, referencing data on a webpage within the same Callout as a different field?
I am seeking to support this form of feature for now, referencing a Portal item within a mapView.
Thank you for the other resources you included! I will look to these to get a better understanding.
CoraColeman
Thank you both so much for your advice, I was able to view my popups in callouts by following the show feature attributes sample! I had to be sure to add and reference both of my feature layers appropriately since I am referencing two!
RTomas
Hello Cora.
I'm stuck at the same point...
How do you defined your popups?
Could you paste your code?
Many thks!
CoraColeman
    // popups
@Override
    // layer 1, trails
        @Override
                aCallout.dismiss();
            int tolerance = 10;
                @Override
                public void run() {
                    try {
                        int counter = 0;
                        Feature feature;
                            counter++;
                            // show CallOut
                            aCallout.show();
                @Override
                public void run() {
                    try {
                        int counter = 0;
                        Feature feature;
                            counter++;
                            // show CallOut
                            aCallout.show();
@Override
    } else {
@Override
    super.onPause();
    aMapView.pause();
@Override
    super.onResume();
    aMapView.resume();
CoraColeman
By the way, you can ignore this part that I included above, as it does not involve anything from that code sample:
@Override
    } else {
