Feature Layer Query - Unable to query the Feature Layer getting "com.esri.arcgisruntime.io.JsonEmbeddedException: Failed to execute query.
719
07-01-2022 02:46 AM
VijayJain
No pending exception expected: java.util.concurrent.ExecutionException: com.esri.arcgisruntime.io.JsonEmbeddedException: Failed to execute query.
2022-07-01 15:13:07.026 14754-15023/com.sedintechnologies.workbook.dev A/es.workbook.de: runtime.cc:638] at java.lang.Object com.esri.arcgisruntime.internal.concurrent.b.get() (SourceFile:18)
2022-07-01 15:13:07.026 14754-15023/com.sedintechnologies.workbook.dev A/es.workbook.de: runtime.cc:638] at void com.sedintechnologies.workbook.view.arcMap.MapWorker$getFeatures$2.invokeSuspend$lambda-0(com.esri.arcgisruntime.concurrent.ListenableFuture, java.util.List) (MapWorker.kt:107)
2022-07-01 15:13:07.026 14754-15023/com.sedintechnologies.workbook.dev A/es.workbook.de: runtime.cc:638] at void com.sedintechnologies.workbook.view.arcMap.MapWorker$getFeatures$2.$r8$lambda$j99awo9utUKbxubff5VG2532Ur4(com.esri.arcgisruntime.concurrent.ListenableFuture, java.util.List) (MapWorker.kt:-1)
2022-07-01 15:13:07.026 14754-15023/com.sedintechnologies.workbook.dev A/es.workbook.de: runtime.cc:638] at void com.sedintechnologies.workbook.view.arcMap.MapWorker$getFeatures$2$$ExternalSyntheticLambda0.run() ((null):-1)
2022-07-01 15:13:07.026 14754-15023/com.sedintechnologies.workbook.dev A/es.workbook.de: runtime.cc:638] at void com.esri.arcgisruntime.internal.concurrent.g.b() (SourceFile:4)
2022-07-01 15:13:07.026 14754-15023/com.sedintechnologies.workbook.dev A/es.workbook.de: runtime.cc:638] at void com.esri.arcgisruntime.internal.concurrent.e.a() (SourceFile:35)
2022-07-01 15:13:07.026 14754-15023/com.sedintechnologies.workbook.dev A/es.workbook.de: runtime.cc:638] at void com.esri.arcgisruntime.internal.concurrent.b.a() (SourceFile:12)
2022-07-01 15:13:07.026 14754-15023/com.sedintechnologies.workbook.dev A/es.workbook.de: runtime.cc:638] at void com.esri.arcgisruntime.internal.concurrent.b.a(com.esri.arcgisruntime.internal.concurrent.b) (SourceFile:1)
2022-07-01 15:13:07.026 14754-15023/com.sedintechnologies.workbook.dev A/es.workbook.de: runtime.cc:638] at void com.esri.arcgisruntime.internal.concurrent.b$a.a() (SourceFile:1)
2022-07-01 15:13:07.026 14754-15023/com.sedintechnologies.workbook.dev A/es.workbook.de: runtime.cc:638] at void com.esri.arcgisruntime.internal.jni.CoreTask.onTaskCompleted() (SourceFile:4)
2022-07-01 15:13:07.026 14754-15023/com.sedintechnologies.workbook.dev A/es.workbook.de: runtime.cc:638] Caused by: com.esri.arcgisruntime.io.JsonEmbeddedException:
