"Unfortunately, <app name> has stopped.
6542
02-13-2014 12:49 PM
karldailey
I'm can launch android apps, but not ones that deal with ArcGIS libraries.  When I try to create a basic map or launch an ArcGIS sample, I get "Unfortunately, <app name> has stopped."  once it hits the emulator.
I followed the steps here: http://blogs.esri.com/esri/arcgis/2013/11/25/setting-up-the-android-emulator/
The settings for my emulator is as follows:
Device: Nexus 4 (4.7", 768 x 1280:xhdpi)
Target: Android 4.3 - api level 18
CPU/ABI: Intel Atom (x86)
RAM 658
VM Heap 64
Internal storage 200 MiB
SD Card: size 34 MiB
Use host GPU checked
My log cat has the following:
02-13 17:39:58.080: D/dalvikvm(2162): GC_FOR_ALLOC freed 331K, 16% free 2926K/3448K, paused 11ms, total 11ms
02-13 17:39:58.290: D/ArcGIS.LifeCycle(2162): map.onSizechanged
02-13 17:39:58.480: W/dalvikvm(2162): threadid=11: thread exiting with uncaught exception (group=0xb0ee1648)
02-13 17:39:58.480: E/AndroidRuntime(2162): FATAL EXCEPTION: GLThread 93
02-13 17:39:58.480: E/AndroidRuntime(2162): java.lang.IllegalArgumentException: No configs match configSpec
02-13 17:39:58.480: E/AndroidRuntime(2162):  at com.esri.android.map.MapSurface$a.chooseConfig(Unknown Source)
02-13 17:39:58.480: E/AndroidRuntime(2162):  at android.opengl.GLSurfaceView$EglHelper.start(GLSurfaceView.java:1024)
02-13 17:39:58.480: E/AndroidRuntime(2162):  at android.opengl.GLSurfaceView$GLThread.guardedRun(GLSurfaceView.java:1401)
02-13 17:39:58.480: E/AndroidRuntime(2162):  at android.opengl.GLSurfaceView$GLThread.run(GLSurfaceView.java:1240)
karldailey
I'd also like to note that it works fine when pushing to my HTC Phone, but not an emulator
RobertBurke
Please could you share the contents of your Console window too?
Here is what mine looks like after a successful launch.
[2014-02-19 13:58:36 - HelloWorld] ------------------------------
[2014-02-19 13:58:36 - HelloWorld] Android Launch!
[2014-02-19 13:58:36 - HelloWorld] adb is running normally.
[2014-02-19 13:58:36 - HelloWorld] Performing com.esri.arcgis.android.samples.helloworld.HelloWorld activity launch
[2014-02-19 13:59:01 - HelloWorld] Launching a new emulator with Virtual Device 'Nexus7Haxm'
[2014-02-19 13:59:05 - Emulator] emulator: device fd:880
[2014-02-19 13:59:05 - Emulator] HAX is working and emulator runs in fast virt mode
[2014-02-19 13:59:07 - Emulator] creating window 0 0 608 972
[2014-02-19 13:59:07 - HelloWorld] New emulator found: emulator-5554
[2014-02-19 13:59:07 - HelloWorld] Waiting for HOME ('android.process.acore') to be launched...
[2014-02-19 13:59:37 - HelloWorld] HOME is up on device 'emulator-5554'
[2014-02-19 13:59:37 - HelloWorld] Uploading HelloWorld.apk onto device 'emulator-5554'
[2014-02-19 14:00:00 - HelloWorld] Installing HelloWorld.apk...
[2014-02-19 14:00:05 - HelloWorld] Success!
[2014-02-19 14:00:05 - HelloWorld] Starting activity com.esri.arcgis.android.samples.helloworld.HelloWorld on device emulator-5554
[2014-02-19 14:00:05 - HelloWorld] ActivityManager: Starting: Intent { act=android.intent.action.MAIN cat=[android.intent.category.LAUNCHER] cmp=com.esri.arcgis.android.samples.helloworld/.HelloWorld }
Rob Burke
RobertBurke
You might try setting the RAM to 512.
And have a look at the 5 steps in this other posting:
http://forums.arcgis.com/threads/99926-unfortunately-HelloWorld-has-stoped?p=367162#post367162
Please let us know if it works!
Rob Burke
karldailey
this is my console:
[2014-02-22 18:29:33 - SimpleMap] ------------------------------
[2014-02-22 18:29:33 - SimpleMap] Android Launch!
[2014-02-22 18:29:33 - SimpleMap] adb is running normally.
[2014-02-22 18:29:33 - SimpleMap] Performing com.esri.arcgis.android.sample.simplemap.SimpleMapActivity activity launch
[2014-02-22 18:29:33 - SimpleMap] Automatic Target Mode: Unable to detect device compatibility. Please select a target device.
[2014-02-22 18:29:37 - SimpleMap] Application already deployed. No need to reinstall.
[2014-02-22 18:29:37 - SimpleMap] Starting activity com.esri.arcgis.android.sample.simplemap.SimpleMapActivity on device emulator-5554
[2014-02-22 18:29:38 - SimpleMap] ActivityManager: Starting: Intent { act=android.intent.action.MAIN cat=[android.intent.category.LAUNCHER] cmp=com.esri.arcgis.android.sample.simplemap/.SimpleMapActivity }
karldailey
I had also done the steps you mentioned in the previous post that include:
1-ensure that you have �??ARM EABI v7a System Image installed
2-configure the Intel Hardware Accelerated Execution Manager by executing the <sdk>/extras/intel/Hardware_Accelerated_Execution_Manager/IntelHAXM.exe program
3-create an Android 4.0.3 AVD and enable the GPU emulation hardware property
4- if you are using eclipse in run configuration find target tab scroll down to see command line and type -gpu on
5- now your problem should be solved
but I still get the error.  I think for some reason its not detecting or running opengl?
I see this in the log cat:
02-22 21:58:43.206: D/libEGL(1653): Emulator without GPU support detected. Fallback to software renderer.
