Hi Community,
We are working on a project to create a LRS, where we are dependend on external data. That means that centerlines as input for our LRS are managed outside our database. We receive messages in case of a Create, Update and Delete event in this external database, and therefore need to update our LRS based on these event messages. We are running into a problem when trying to update a route when a centerline is geometrically partially updated.
Here is an example:
1. We have a route that exists of 3 centerlines (16, 17 and 18)
2. We received an update event on centerline 16 and appended this new centerline to the centerline feature class in the LRS
3. As preparation to append the new route, we create a new polyline outside the LRS (blue selected line) and use this as Source Route when running the Append Routes tool
4. We run the Append Routes tool with the following settings:
Since the route id is already present in the LRS, we want to Retire the existing route by its route ID, and we want the tool to use existing centerlines.
However, because there are now two partially overlapping centerlines, the new route cannot be appended to the LRS and gives the following error message:
Partially matched centerlines found. A list of offending OIDs is available below.
Has anyone a workaround for this problem? We cannot use the Realign tool in ArcGIS Pro, and are dependent on the tools available in the arcpy locref toolbox.
I hope anyone out there can come with some ideas on a work around!
Mirek
