M Tolerance/Resolution Suggestions when Transitioning LRS to Roads & Highways
1343
10-17-2023 11:53 AM
KathrynWesson
I'm prepping our LRS for transitioning over to R&H, and I'd like to know if I should change the default M tolerance and resolution. Our current LRS specs are below:
Our events are only measured to thousandths of a mile (3 decimal places) and there is no exception to this, so what is the point of having a more precise tolerance/resolution? What do other organizations set as their defaults? It just seems like it would keep the data "cleaner" to not allow measures more precise than the event data, but I would love to hear other thoughts on this...TIA!
NathanEasley
Hi Kathryn,
I'd suggest taking a look at this white paper the Roads and Highways team created that discusses measure precision in more detail.
It specifically addresses how to model your data for a 3 decimal place measure precision and what that will look like within the rest of your system.
Nathan
ArcGIS Roads and Highways team
NathanEasley
Hi Kathryn,
Nathan
KathrynWesson
This is awesome, thank you very much!
