Lollipops and loop calibrations
1445
02-12-2020 06:37 PM
ElAttar__Ihab
Hello,
I loaded routes successfully in my network. I have a few gapped routes, lollipops and some loops in my network.
Is there a tool to flag lollipops or  loops that have not properly calibrated on the initial load of the network ?
Regards,
Ihab
NathanEasley
Hi Ihab,
There isn't a tool within Roads and Highways in ArcMap that will give you this information.  One way to find routes that aren't calibrate or are not calibrated in a strictly increasing direction is to add your network layer to the map and turn on the route measure anomalies in the routes tab of the layer properties.
Nathan
Esri Roads and Highways team
NathanEasley
Hi Ihab,
Nathan
RyanKoschatzky
You can run the detect Detect Non-monotonic Routes toolbox tool to find issues.
Depending on how your setup, Shape.STGeometryType() = 'MultiLineString'
Can return your gaps, lollipop and loops. If you use the route tab in your layer properties on the route layer you can visual see issues, see Nathan's post.
HTH
GraemeBrowning_Aurizon
I know that this thread relates to using Roads and Highways in ArcMap but I am wondering whether similar functionality exists when using Roads and Highways in ArcGIS Pro 3.0.0?
In other words, if @ElAttar__Ihab was using ArcGIS Pro 3.0.0 when they asked:
what would the answer be?
