Anyone has guidelines of how to perform QC in Event editor app for Roads & highways? I am able to identify the gaps and Overlaps using the app but not sure how to correct the errors?
1370
07-26-2019 06:36 AM
SatyamChauhan
Any material, document or guide will be appreciated. Thank you.
NathanEasley
Hi Satyam,
Once you identify any QC issues with your events, you can find those events that need changes via the search tools (https://enterprise.arcgis.com/en/roads-highways/latest/event-editor/select-events-by-route.htmhttps://enterprise.arcgis.com/en/roads-highways/latest/event-editor/selecting-events-and-routes-by-a...https://enterprise.arcgis.com/en/roads-highways/latest/event-editor/selecting-events-and-routes-by-g...).
Once you select the events that need updated, go ahead and make whatever changes are needed to eliminate any gaps or overlaps in the event attribute table.
Nathan
Esri Roads and Highways team
NathanEasley
Hi Satyam,
Nathan
SatyamChauhan
Thank you Nathan:
The reference links seems great source to start.
Kind regards,
Satyam Chauhan
GIS Technician
Engineering & Transportation Division
Municipality of Chatham-Kent
RyanKoschatzky
For the most part I cannot foresee a scenario for overlaps but we all model the data differently with different events so there might be valid reason for your data.
For gaps, are the gaps supposed to be there? For instance you have an event for curb and gutter, you probably should have gaps. If your modeling pavement type, there probably shouldn't be a gap in pavement type.
Based upon the event, how you model your data and what your temporal expectation is you can change the from/to measure in the table to fill the gap or remove the overlap. You can do this with the 'select by attribute tool' in Event Editor or use a third party tools. Additionally if the area is really bad I might retire all the records with the same from date creating a begin record using 'select by attribute tool' in Event Editor and then reapply new data with the same from date over that area with 'add linear events tool' in Event Editor. This method can help ensure that the temporal data is clean as well as opposite to just using 'add linear events tool' in Event Editor over the route to fix the area and retiring the bad data.
Unfortunately I think when you are down this far in the QC fixing it is a route by route, event by event type analysis and fixing, there are no clean bulk fixing because what ever method you are using it has been my experience it is only the correct method half the time.
Hope this helps
