Hi all,
I've been attempting to update the JSON of a Feature Service with new Coded Domain Values. I have managed this with one of my other features, but in another I have run into this error, where xxxxx equals the domain name.
{ "error": { "code": 500, "message": "ERROR: Domain is used beyond the scope of the service. Domain name: xxxxxxxx", "details": [] } }I've read that this is because there is another service that uses this same domain name - although from my investigations this doesn't seem to be the case. We are using ArcGIS Enterprise 10.7.1, and not AGOL.
I would prefer to continue editing services through the Rest API because of its utility, but would an alternative be to download a local copy of the Service to my ArcMap client and edit the domain through there and republish, or would I likely run into the same Domain Name issue?
Any suggestions or advice are welcome!
Henry,
Have you tried changing the name of the Domain then editing the new Domain?
There is this support page: Error: Failed to update domain: ERROR: Domain is used beyond the scope of the service.
Thank you for the input,
Unfortunately when I try to change the Domain name via the same method I still get hit with the Error: 500 message, with the old domain name I wanted to change listed instead of the new one I was attempting to input.
I will give the Solutions Deployment tool through ArcGIS Pro a shot, see if that is any easier.
