Retrieving attachments from ArcGis Rest Service
3925
11-27-2014 01:00 PM
AndrewWigglesworth
Hi there,
I'm pretty new to the ArcGis rest services. I'm having problems determining when an attachment exists on a feature layer, and retrieving the attachment. I'm using C#, but accessing the feature layers through ArcGis Rest API. How do i get the Query layer to return the attachments along with the features that i can access. I'm able to navigate to them through the web browser but i can't get them through the API.
Below is the C# data mapping that i have laid out, everything else returns properly but the attachments do not.
namespace DataModels
    [DataContract]
    public abstract class FeatureLayer
        [DataMember]
        public string objectIdFieldName { get; set; }
        [DataMember]
        public string globalIdFieldName { get; set; }
        [DataMember]
        public string geometryType { get; set; }
        [DataMember]
        public Spatialreference spatialReference { get; set; }
        [DataMember]
        public Field[] fields { get; set; }
    [DataContract]
    public class Spatialreference
        [DataMember]
        public int wkid { get; set; }
        [DataMember]
        public int latestWkid { get; set; }
    [DataContract]
    public class Field
        [DataMember]
        public string name { get; set; }
        [DataMember]
        public string type { get; set; }
        [DataMember]
        public string alias { get; set; }
        [DataMember]
        public string sqlType { get; set; }
        [DataMember]
        public Domain domain { get; set; }
        [DataMember]
        public object defaultValue { get; set; }
        [DataMember]
        public int length { get; set; }
    [DataContract]
    public class Domain
        [DataMember]
        [DataMember]
        [DataMember]
        public Codedvalue[] codedValues { get; set; }
    [DataContract]
    public class Codedvalue
        [DataMember]
        [DataMember]
        public string code { get; set; }
    [DataContract]
        [DataMember]
        public Geometry geometry { get; set; }
        [DataMember]
        public Boolean hasAttachments { get; set; }
        [DataMember]
        public AttachmentInfos attachmentInfo { get; set; }
    [DataContract]
    public abstract class Attributes
        [DataMember]
        public int OBJECTID { get; set; }
    [DataContract]
    public class Geometry
        [DataMember]
        public float x { get; set; }
        [DataMember]
        public float y { get; set; }
    [DataContract]
    public class AttachmentInfos
        [DataMember]
        public Attachments[] attachments;
    [DataContract]
    public class Attachments
        [DataMember]
        public string id { get; set; }
        [DataMember]
        public string contentType { get; set; }
        [DataMember]
        public int size { get; set; }
        [DataMember]
JSON query:
StringBuilder sb = new StringBuilder(requestLayer);
            sb.Append("query?");
            sb.Append("where=RequestID<>''&");
            sb.Append("returnCountOnly=false&");
            sb.Append("returnIdsOnly=false&");
            sb.Append("outFields=OBJECTID,RequestID,Description,CustomerNumber,Note,Employee&");
            sb.Append("token=" + token);
