Relates stripped from services on ArcGIS Server 11.1
548
02-08-2024 06:00 PM
Labels (2)
BrianVan_Nostrand
Has anyone seen an issue where relates established in APRX files are stripped from map services published from those documents? We have an APRX file with two layers and four sand alone tables, and each of the two layers has a relationship set for each of the four tables. They show up fine in the APRX, and worked in prior versions of server, but we recently upgraded to 11.1 and the existing service has had all of its relates removed. I've rebuilt the APRX and republished to the same effect. Any ideas would be appreciated!
Brian
