"No edits ('adds', 'updates', 'deletes', or 'attachment edits') were specified."
1870
11-28-2023 01:38 AM
SantoshS
Hey guys,
adds=[
"attributes": {
"pid": "1033",
"parentid": "1033",
"instanceid": "1",
"moduleid": "PRJLOCN",
"mapcontrolname": "PRJLOCNGISMapControl",
"geometryid": "1",
"projectname": "locationTest",
"projectcode": "locationTest",
"title": "s",
"description": ""
"geometry": {
"rings": [
-12444372.055961894,
3771472.2607350508
-12442843.31539619,
3771472.2607350508
-12442843.31539619,
3769332.0239430647
3769332.0239430647
3771472.2607350508
"spatialReference": {
"wkid": 102100,
"latestWkid": 3857
This is the JSON I'm passing to add (I've removed add when passing) and when I do it,
 "error": {
  "code": 500,
  "message": "Unable to complete operation.",
  "details": [
Getting these errors when trying to add the data. What could be the issue?
ChristopherCounsell
MVP Frequent Contributor
applyEdits requires an edits parameter. If you remove 'adds', then you haven't specified 'adds', or updates or deletes for that matter. This is why you are getting the error message.
Your request should look like this:
    "id" : 0,
    "adds" : [
        "geometry" : {
    		    "x": -143.501,
    		    "y": 57.043000000000006
        "attributes": {
          "datetime": 1272210710000,
          "depth": 31.100000000000001,
          "region": "Andreanof Islands, Aleutian Islands, Alaska"
        "geometry": {
          "x": -72.865099999999927,
          "y": -37.486599999999953
        "attributes": {
          "datetime": 1272210142999,
          "depth": "40.x",
          "region": "Bio-Bio, Chile"
    "updates": [
        "geometry": {
          "x": -149.450,
          "y": 60.120
        "attributes": {
          "OBJECTID": 50,
    "deletes": [
      19,23
    "id": 1,
    "deletes": [
      34,44
https://developers.arcgis.com/rest/services-reference/enterprise/apply-edits-feature-service-.htm
SantoshS
I'm adding like this to check if it's working properly. Got the error when I added the add JSON. Will this require Edits parameter as well?
ChristopherCounsell
Ah - that's looks ok.
Does it work without the URL attribute? if the unencoded value is throwing it off?
Is the feature valid? Polygon, fields, unique values etc?
RiyaD67
I need help with a similar issue i am facing .i am using a Omnistudio Integration Procedure
The request that I am sending is this
  "ElapsedTime"1615,
  "Type""Rest Action",
  "Input": {
    "body": {
      "adds""{attributes={objectid=8402, active_date=11/26/2024, application_status=Pending Acceptance, inactive_date=11/26/2024, permit_type=Pre Construction Notification, permit_id=0cEWC0000002KM12AM, project_name=Sunnyvale Wetland Restoration Project, application_id=BL-0000000299, application_date=3/3/2025, construction_start=1/22/2025, construction_end=1/15/2026, agency=Other, project_size=45, complaint_type=Hazardous Waste, complaint_location_desc=No Description, complaint_desc=too much waste, complaint_ongoing_occurrence=Yes, complaint_timeframe=Exact}}"
    "headers": {
      "Authorization""Bearer plCzAOOuCpBs2AIQMVpZpcOWdQ1Pu1lDigD9edWZijqepnd5T-aIBFyDGNwLZN3De0uNq36PP3S9YCbyDXuJuFOpplW_AJaCIhPK46E3qd0ucw0h-2f7MfYuuJ3QI521HcJDZTa9EAhMJQzm8utc-JWc4pyFQOxJSCXkU2CVfYo."
  "Status"true
The response I get is this
  "error": {
    "details": [
      "No edits ('adds', 'updates', 'deletes', 'attachment edits', or 'asset maps edits') were specified."
    "message""Unable to complete operation.",
    "code"500
  "rawHttpResp": {
    "adds": [
        "attributes": {
          "complaint_timeframe""Exact",
          "complaint_ongoing_occurrence""Yes",
          "complaint_desc""too much waste",
          "complaint_location_desc""No Description",
          "complaint_type""Hazardous Waste",
          "project_size""45",
          "agency""Other",
          "construction_end""1/15/2026",
          "construction_start""1/22/2025",
          "application_date""3/3/2025",
          "application_id""BL-0000000299",
          "project_name""Sunnyvale Wetland Restoration Project",
          "permit_id""0cEWC0000002KM12AM",
          "permit_type""Pre Construction Notification",
          "inactive_date""11/26/2024",
          "application_status""Pending Acceptance",
          "active_date""11/26/2024",
          "objectid"8402
  "rawResponse": {
    "error": {
      "details": [
      "code"500
I guess the HTTP hits the url but still its unable to access it
