Limit number of rings a circle polygon is made up of.
2420
09-13-2013 01:00 PM
ChristopherBlinn1
ArcGIS Server 10.0 SP5
ArcGIS Javascript API 3.6
I'm passing a the geometry of a drawn graphic to a parameter in my Identify url.  Everything is working fine except when I pass the geometry of a polygon circle.  I'm pretty sure the issue is because I'm passing many polygon rings into the parameter and my service is not liking that.
Do I need to "generalize" my circle before passing it's geometry or can I limit the maximum number of rings a circle can have when being drawn?
Here's the workflow:
First I draw a shape.  Each shape references a geometry in a Draw toolbar I created.  For circle I am setting the drawing toolbar like so:
tb.activate(esri.toolbars.Draw.CIRCLE);
*Note, I did notice options can be passed in the activate, but cannot find those available options in the API.
I then create my url parameters on the "draw-end" event:
tb.on("draw-end", createSelectURL);
identifyURL + "&geometry=" + JSON.stringify(e.geometry)
...and as I stated before, this works.
So, are my options just to generalize the shape geometry, or can I limit the number of rings before drawing the shape, or perhaps there is something I am not thinking of?
Any help is appreciated, and to all, Happy Friday!
Chris B.
nicogis
do you pass multiple circle in get or in post?
