Layer query for all feature IDs timesout
3420
05-04-2011 09:11 AM
by Anonymous User
Not applicable
Original User: jmurdoch
I'm running the following query which consistently timesout:
http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer/0/...>=0&returnIdsOnly=true&f=json
Is there a way to stream the response or paginate results so that this does not occur?  If no, how else may I generate a list of all feature objectIDs for a layer?  Thanks.
by Anonymous User
Not applicable
Also, slightly unrelated, there may be a bug in the geometryType filter parameter.
In trying to reduce the result set using a filter by geometryType, I ran this query:
http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer/0/...<500&geometryType=esriGeometryPolyline&f=pjson
The param value validation seems to be working, i.e. if I enter an invalid type for 'geometryType', I  receive an error as I would expect.  Howerver, the result set returned for the query above contains 500 features of type esriGeometryPoint, i.e. not polylines.
