Is it possible to create an ArcGIS Online user via a rest endpoint?
4971
11-13-2014 09:32 AM
PaulLivingstone
Trying to do this in Python but can't see anything in the API.
PaulLivingstone
Found that you can create an ArcGIS Online user via the following endpoint:
     http://<yourcompany>.maps.arcgis.com/sharing/rest/portals/self/invite
You can call this after you have obtained a token from:
     https://www.arcgis.com/sharing/generateToken
TimothyHales
Esri Notable Contributor
You can do this with your own portal, but I am not sure the endpoint is open for ArcGIS Online.
Create User - ArcGIS REST API
PaulLivingstone
Thanks for the response. Unfortunately I think you are right.
PaulLivingstone
