I tried to establish direct connection between SDE and java
787
12-15-2021 01:00 AM
santhoshT
1) I used the below code to the SDE 10.3 direct connection  from java
String instance = "1234";//sde port
String server="host";
if (conn == null) {
try {
conn = new SeConnection(server, instance, database, userName, password);
System.out.println("Connection Successful");
I got the below error
[java.lang.UnsatisfiedLinkError: no sdejavautil in java.library.path] with root cause
I have to install the ArcSDE on my local machine so that I can able to avoid this issue. Could you please share the download path for ArcSDE 10.3?
2)  ArcGis is licensed or open source?
Could you pls advise...!
