How to call a Rest SOE in flex?
2882
12-27-2012 09:21 AM
XintaoLiu
Are there any examples or sample codes? Thanks!
RichardWatson
I have never used Flex but it looks like the help has samples:
Go to this page:
http://resources.arcgis.com/en/communities/flex-api/
Look on the right hand side for Samples.
XintaoLiu
Any of your comments and suggestions are highly appreciated!
RichardWatson
Go to this page:
RichardWatson
REST is based on HTTP so in order to call the REST SOE endpoint you simply send an HTTP request (GET or POST) to the endpoint (URI) using whatever mechanism is provided by the Flex framework.
The URI that you send the request to consists of a fixed prefix and REST SOE schema specific suffix.  Use the REST Services Directory in order to understand how to form the URL.  It is essentially a hierarchical scheme.
The typical response to a request is JSON.
If you want to see trivial SOE examples then look in:
C:\Program Files (x86)\ArcGIS\DeveloperKit10.1\Samples\ArcObjectsNet
I think that you should be able to find a large number of Flex examples which call HTTP services.  The REST SOE is really just a REST endpoint which is called using HTTP.
XintaoLiu
Thanks a lot!
nicogis
